Question about W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer
Shampoo not releasing when i hold the trigger
Won't dispense shampoo......cleaned it and clear water is fine. No shampoo soap dispensed?????
check the linkage between the dispense trigger assembly and the actual shampoo valve
May 03, 2015 | Vacuums
What is the best way to unclog the tubing from the shampoo container to the water supply. My machine, I thought, was working well! Then I realized I did not see movement in tank of shampoo and the carpet...
the machine has to run for few minutes in the parked postion to heat the water or it will not dispense, for one for twoif you turn the heat off and add hot water to the tank instead it will bypass the heating and work in the meantime best way to unclog after following these steps is there is an airlock in tline turn heat off in parked position and motor on hold the trigger down for about 15 to 20 seconds release and turn off, then in parked position (locked) upright pull trigger and hold then turn on power you then will have ceased the airlock if you want to clean the unit after trying this baking soda and apple cider vinegar is best, drop the handle to ground pull the tank out and loof for the round area that the tank plug goes into take a push pin and poke the holes, then dump the baking soda and vinegar that is mixed from a cup by a few drops to sizzle in there, lift and lock and turn on holding the trigger and there ya go, have fun
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
Sprayer on carpet cleaner won't release water
Hello! If your Dirt Devil carpet cleaner is not dispensing cleaning solution, there may be air buildup in the line. Try priming the trigger.
1. Plug the cleaner in.
2. Recline the handle and pump the trigger about 30 times
3. Power the clean on.
4. Hold the trigger in for abut 30 seconds.
The cleaner should start to dispense the cleaner. Hope this helps!
Aug 27, 2014 | Dirt Devil Carpet & Rug Shampoo 1700912044
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Have a D4 model rainbow vaccum cleaner and want 2 no how 2 shampoo with it please help me
put cleaning solution into the proper receptacle lower brushes making contact with the surface to be cleaned. turn the on off switch on. start at the edge of the carpet squeezing the trigger for cleaning solution release and pull backwards.release trigger. roll vacuum back to begining position and pull backwards without squeezing solution release trigger. push back to the top slightly overlapping the first pass and repeat procedure. after rug is been completely shampooed allow to dry. after rug is dry sweep with broom
Feb 26, 2011 | Vacuums
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Jun 01, 2008 | VAX Appliances Vacuums
How do I work this dam thing?????
How do I work this?
Bissell 1699 ProHeat Clear View Upright Steamer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Bissell has a holding tank to the solution and the recovery tank for the water and soap you pick up -- -both are removable for cleaning purposes – there is a trigger assm on the handle to release the Bissell Soap or detergent that you are using – (low sudsing) and there should be a switch on the bottom of the unit to activate the revolving brushes. So the best way to shampoo the rug is to do it on the back pull – when you pull back you are dispensing the water solution and shampoo by squeezing the trigger assm, the brushes are agitating the carpet and the vacuum part is picking up the water. This is about as simple as I can get it – please refer to the owners manual for the trouble shooting part of the manual or check with your local vacuum cleaner dealer in your area and in the yellow pages under vacuums, or call the Bissell factory phone # or use the website.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac man
Apr 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Plugged water line?
The trigger in the handle is clipped into two plastic snaps. When the trigger is pressed, the trigger pivots in these snaps and the pressure is transmitted through a rod connected to the trigger down to a valve located under the water tank. If the machine has been carried by the top handle insead of the carry handle that is incorporated into the water tank, the extra stress on the trigger will break off the snaps and the trigger will not function properly. Take the water tank off the machine and press the trigger. Observe the valve below the tank support and see if the rod is pressing down on it.
You might also check the hoses that come down the handle where they turn at the bottom of the tank. Sometimes they kink there and this will restrict water flow.
If you have been using the wrong shampoo, that is shampoo not designed for hot water extractors, it is possible for it to congeal in the lines and plug them.
Jan 27, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Logo
Top Vax Vehicle Parts & Accessories Experts
Bigaitch
Level 1 Expert
seanwalters1
Level 1 Expert
David Grady
Level 1 Expert
Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
