Question about Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks
Metabo uhe 28 multi gearbox assembly manual - Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks
2 Suggested Answers
  • 14 Answers
SOURCE: It will not work with my power inverter in my
The Metabo UHE28 has the Metabo Electronics. The electronics in the tool is designed to read a true sine wave. The power inverter in your truck changes the DC current to AC and puts out what is called an artificial sine wave. These two are not compatable. In short the electronics in the drill does not like inverters. It will not work.
Posted on Oct 08, 2014
Hi I have a metabo hammer drill une 2850 won't start
UHE2850 metabo first look if its the powercable have no phase fracture second is there depending 2 years warranty time on left ?
The switch or only dirt between brush and brushholder inside or an electronic assembly defect or the switch electric field armature . only a slide contact loose sometimes its not hard to find by metabo machines.
Mar 26, 2016 | Metabo Drills
How do I remove the chuck of a Metabo BST 12?
First you will need to remove the "Set Screw" in the middle of the chuck. this screw is reverse thread. after the screw is removed the chuck is standard thread you it can simply be unscrewed.
Jun 04, 2014 | Metabo Drills
How to assemble metabo khe24sp gearbox for rotary hammer drill
DO NOT THAT !! its cheaper to get yourself an whole new gearbox yes instead of the time you will spend and you have no maintenance kit for this machine because of the price the parts are not expensive . you will have again trouble if you will replace parts in a short time . with this machines because of the striking pin that will not get good airtight anymore by this machines. you can not work the time to spend because of the complete price of this complete to get gearbox .
Apr 10, 2013 | Metabo 600223420 KHE-D24 1" SDS-plus...
Metabo uhe 28 multi code
http://www.metabo.com/International-Homepage-english-The-craftsman-s-brands-world.2786.0.html?&L=2786 You have no question but I do see the name metabo so hope this helps. It's the Metabo factory site where you can get parts breakdowns and more.
Jan 04, 2013 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Metabo BHE 22 manual wanted
you can ask to your metabo seller to give one to you
or here:http://www.metabo.us/E-Mail.3620.0.html
ask for a free pdf copy
Nov 01, 2012 | Metabo 600242420 BHE22 7/8" SDS-plus...
How to do maintenance on metabo sbe710
for maintenance:
after use
1: cleanup with air pressure(inside of motor by motor vent)
weakly
2:clean chuck with brake cleaner and lubricate with metabo grease
at 3 month
3 check motor brush
when motor brush are worn,check ball bearing on armature,extended motor cleanup,gearbox check and grease change if it is dirty,
Oct 10, 2012 | Metabo Sbe710 1/2-in 0-1,000 / 0-3,100 Rpm...
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Metabo model 6030 will not hammer help out
There are several possibilities. Remove the cover from top of gearbox. The piston / sleeve assembly will be visible. Wiggle the assembly to check for side play. If the assembly is loose side-to-side, loosen one of the support tracks (two allen screws). Wedge a screwdriver between the track and the housing and then re-tighten the screws. Another possibility is that the piston o-ring is worn. stand the tool on its nose, if the piston falls quickly forward, the o-ring is worn out. This part is no longer available. If the piston does not move forward, smack the nose firmly against the work bench. If it still does not move, the piston lube may have dried out. Shoot some WD40 into the sleeve for a quick test. Another possibility is end wear of all hammering parts in the tool. This can be difficult to determine if you dont know what they looked like originally.
May 16, 2009 | Metabo Drills
Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks Logo
77 people viewed this question
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
