Question about Baumatic MEGAWDSS Front Load Washer / Dryer
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
    Sergeant:
    Champion:
  • 216 Answers
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
Posted on Jun 29, 2009
Hi, I have a baumatic BWMI 1206.1 washing machine. Once a cycle is started it never completes, I have to manually set to spin. Do you have any idea what could be wrong?
I'm not a washing machine repairman, but this sounds suspiciously like a worn-out or defective timer. Only guessing here, but perhaps (USD) $50 in parts plus the cost of the service call. This model seems to have a fairly good reputation and considering the cost of washing machines, I'd probably be inclined to have it professionally serviced. It doesn't sound like something you can fix yourself.
Also, most newer washers will not spin if the load of wet clothing is not balanced (evenly distributed) - of course you have likely checked this. Good luck
Jan 04, 2015 | Baumatic Washing Machines
Making a banging noise on spin and throwing itself around the kitchen. i think the drum has come loose?????
well sort off.
likely is that the dampers on the underside of the drum have failed. (they are like shock absorbers)
The drum is also suspended from a couple of springs, you also need to check these.
To check springs the lid needs to be removed.
There normally are 2 dampers attached to the drum and the frame.
They are accessed by tipping the machine onto its side.
However the machine is heavy and make sure you disconnect power and water if you want to investigate.
Cost of new dampers are around 50 each.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Baumatic MEGAWDSS Front Load Washer /...
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
My Baumatic MEGA6SS washer is still full of water after the cycle is complete. Tried starting it on 'Drain' and nothing happens.
sounds like your drain pump is not working. that will be the case if there is no noise. if you hear something when it should be draining, check the screen to be sure it's not plugged.
Oct 11, 2009 | Baumatic MEGA6SS Front Load Washer
My megawdss will not spin everytime can you help
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 27, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic washer draining but not spinning
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic WD55 Washer Dryer - How Do i work it??!
machine needs to be on half load for dryer to operate
Dec 26, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic MEGAWDSS Front Load Washer / Dryer Logo
136 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
noel
noel
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
