Question about LG WM2701HV Washer
The LG WM2701HV washer is leaking from the bottom. The machine otherwise is in good condition.
bestdarngood
  • 3037 Answers
SOURCE: LG front washer keeps getting "LE" error
Regarding the LE EEROR CODE.... This code is also caused by having a residue on the sensors in your unit. You have to use a HE liqud detergent.If you use fabric softner use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vineager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE.
The spinning may be a burnt out motor, you may have to get a repairman on that, I can't be sure on that but I hope this helps solve your problem
Posted on Mar 23, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
praky16
  • 744 Answers
SOURCE: Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Posted on Aug 19, 2009
  • 66 Answers
SOURCE: I have an LG WM2277HW front load washer that is
check ur inlet hoses on the outside of machine, also check the connections inside the panel in back
Posted on May 08, 2010
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
My LG wm2701hv washer will only turn on if I disconnect for 20 seconds and reconnect. Once the load finishes I have to do the same thing all over again. Any ideas?
try holding in the power button for 10-15 seconds while unplugged, if that does not reset, try the same just after plugging back in. good luck.
Mar 30, 2015 | LG WM2701HV Washer
Lg WM2701hv hose squeals while filling
The only solution would be to replace the water valve. You will need a qualified technician to help you.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
I have a LG WM2701HV it is less than a year old and sometimes the washer turns on and other times it doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker is...
How much soap are yall using? The washer is supposed to wash with less water. Too much soap causes problemas. Less than a year? Look for items in the filter.
Jun 09, 2011 | LG WM2701HV Washer
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
My washer is leaking water out the bottom and after cleaning the filter it is still leaking with no visible signs of a bad hose.
very hard to solve without looking but when you cleaned the filter is the rubber seal around it in good condition?
Feb 07, 2011 | LG WM-2277HW Front Load Washer
Sears botched repair on my LG washer (Model WM2701HV). Replaced both boards but suddenly motor does not spin - only hums. Tech claims motor needs to be replaced but it was fine until they replaced the...
If a LG washer hums look into a part called a HALL SENSER it is a small part that go's in the motor at the rear of unit they are known to go and the humming is the give away ..If this helped please vote if you need more help please feel free to contact me..czerney@msn.com
Feb 02, 2011 | LG WM2701HV Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
LG WM2701HV Washer Logo
47 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
