Where to find the capacitor c515 c516 and ic ic206 for a sony tv. kp-fx 532m91
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
C515,C516, IC206 - you specify here are only the part numbers, and not represent the real value of the component. It is designated as the part position on the circuit board. The real values should be printed on each part. google.com/+GopakumarGopalan
Posted on Nov 25, 2013
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: stand by light flashes 6 times
That blinks and flashing have a diagnostic code;
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Hope it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Oct 14, 2008
welcomejee
  • 10594 Answers
SOURCE: sony trinitron 6 red lights
Every part has its unique reference number on schematics and PCB of TV installed.
C515 means Capacitor # 515 and IC206 means Integrated Circuit # 206 mounted on PCB and shown in related schematics.
Jungle IC is technical term used in Sony and Panasonic refers to sync, oscillators, drive stages for horizontal and vertical deflection stages in a TV.
Need further info, let me know.
Posted on Jan 15, 2009
likha
  • 790 Answers
SOURCE: sony trinitron power will not come on sometimes
Hi
Can you give to me your diagnose test result..
Thanks!
Posted on Mar 06, 2009
Why sony 42 trinitron blinks 6 times but won't turn on
There has no horizontal, no raster, goes to the blinking self-diagnosis function immediately.Check C515, C516 and the jungle IC, IC206.
Jul 13, 2014 | Sony Televison & Video
Sony kv-36xbr450 36
breakdown in the horizontal, check the c515, c516 and the jungle ic IC206 which get bad.
Oct 27, 2012 | Sony KV-36XBR450 36" TV
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony model KV32hs420 Powers on for 2 seconds than turns off and standby light flashes 6 times
you have no horizontal output,with a ohm meter check C515 & C516, also check the jungle IC,IC206......... hope this helps.
Feb 16, 2010 | Sony Televison & Video
Sony model # KP-43HT20. power light flashes 6 times.
hello o Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
shaun
Nov 08, 2009 | Sony KP-43HT20 43" Rear Projection...
SONY KDP65XBR2
Those are capacitors, probably on the "D" board or "G" board. What is/ was wrong with your TV?
michtech
Feb 16, 2009 | Sony Grand WEGA KDP-65XBR2 65" Rear...
Sony trinitron 6 red lights
Jan 15, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony KP51-HW40 Rear Projection Tv service manual
6 blinks on sony Check c515 and c516 and the jungle ic IC206.
Dec 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
