Question about Life Fitness T5-0 Treadmill
It shut offs
When running it shuts off
  • 20 Answers
Questions for analysis:
How old is this machine?
What is the condition of the walking belt and deck?
(most problems with treadmills cutting off during use stem from worn walking belts and decks - replacement is always recommended unless unit is less than 1 year old)
If you are able to walk on the edges of the walking belt (away from the center of the deck), run a test to determine if unit is still shutting off. If not this may be another indication of excess friction in the center (walking) area of the walking belt/deck. The only way to be accurate about this test would be to perform an amperage test, testing the machine unloaded, with load at 3mph, and with load walking on the edges of the walking belt
Posted on Dec 03, 2013
If the hydrant runs it wont shut off.if it shut off it will not run.can not get it adjusted to run and shut off at the same time.
Your question imposes an enigma! Can you be more clear. OFF should be OFF and ON should be RUN
Apr 25, 2016 | Air Tools & Compressors
Pull the keys radio never shuts off, I replace the fuse because it was burnt out.
radio will not shut off when car turned off - Car Forums and ...
www.automotiveforums.com > ... > Chevrolet > Cavalier
I have this anyoing problem..when i pull the key out of the ignition the radio ... They could not wire it so that when you opened the door, it would shut off. .... I NEVER had to do anything with the airbag wires or shut the airbag off or anything!
07 Silverado Will Not Shut Off With Key Removed - 1999-2006 & 2007 ...
www.gm-trucks.com/.../115642-07-silverado-will-not-shut-off-with-key...
Jun 27, 2010 - 14 posts - ‎8 authors
The only way I can shut it off is to pull the fue... ... It runs perfect as if I never shut itoff. It is not dieseling it runs like the key is on. The complete vehicle shuts down like it is off ie all dash lights, radio, go of and it will not allow the ...
VW Jetta MKIV/MK4: Stereo doesn't shut off with car 'Volksw
Dec 30, 2015 | Cars & Trucks
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Runs but shuts off automatac
check the oil, most of these have a low oil shut down. If it's full make sure it's sitting level while running. If it still shuts down and is full of oil and level, bypass the low oil shutoff and see if it stays running.
Dec 04, 2012 | Coleman Powermate Premium Plus 6250W...
Electric circulating pump for turbo want shut off
If i am understanding what you are asking then Yes it will run a few minutes after car shuts off,this allows system to cool down.. hope this helps and Please rate this post..
Aug 14, 2012 | 2002 Volkswagen Jetta TDI
Computer shutting off
shutting off when? Shutting off immediately when you try to start it? Shutting off after it has run for a while?
If it is shutting off after it has run for a while, then it is probably running hot. If you try to restart it immediately it will not boot. If you let it cool off for a while then it will boot successfully (definitely a sign of running hot).
Things that make a computer run hot:
1) Dust in the vents, fans, cpu & heat sink and all inside the computer.
2) Fan not working
3) The Thermal Paste on the cpu and heat sink has either dried up or is too thin to keep it cool.
If it shuts down immediately after it has been sitting for a while then it's not running not and your system has some other problem.
Mar 31, 2012 | Computers & Internet
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Chainsaw will run but will not shut off with the run/stop switch
The cut off wire is probably broken before the switch. Depending on the make,you'll need to remove the pull start housing to fix it.
Jul 15, 2009 | Garden
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
Life Fitness T5-0 Treadmill Logo
120 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
