Whats error 33 st prohibit for mitsubishi 1998 lancer
How to replace the hood release cable for Mitsubishi lancer ck2 1998
If your not particular mechanically inclined, than do not attempt this.
You probably will not have the tools.
I would go to a friend who happens to have a LOT of mechanical tools and ask for help.
This is something that would be simple for someone good with their hands.
Jan 07, 2015 | 1998 Mitsubishi Lancer
Where is port obd-ll in mitsubishi lancer 1998
Mitsubishi Lancer OBD 2 port is on lower right corner dash; next to console kick panel
Jul 25, 2014 | 1998 Mitsubishi Lancer
I need A 1998 Mitsubishi lancer rear left light
Well, there are wreckers in your area that may have one. For new, try rockauto.com
Apr 04, 2014 | 1998 Mitsubishi Lancer
1998 mitsubishi lancer 1.5 lt
The 1.5L was never a power house, but the first checks should be
* check if the ECU is throwing an error code. If so this is a vital clue.
* verify the cam belt alignment. This can slip a few teeth and cause all sorts of problems
* verify the timing (assuming your 98 has a distributor or cam position sensor adjustment)
* Pull the injectors and soak them in injector cleaner.
* clean or replace the air filter.
* Check the coolant temp sensor (on the thermostat housing) does not have damaged wires. This sensor is vital for the ECU to decide what timing and mixture is needed.
Mar 26, 2014 | 1998 Mitsubishi Lancer
Trouble code 33 and 21 for mitsubishi pajero
those codes dont conform,refer your user manual for code reader
Feb 11, 2013 | Cars & Trucks
My mitsubishi lancer 1998 engine sparkplug 1 and 4 are always get wet in oil
Look to see if the gasket is leaking above the spark plug.
Nov 09, 2012 | 1998 Mitsubishi Lancer
What is the region of france with a 09 to start
09 refers to a VOIP number or Skype for example.
There is no region of France who's landline (or mobile) number starts with 09.
France City Area Telephone Codes +33 556 Bordeaux
+33 556 Cannes
+33 549 Chauvigny
+33 233 Cherbourg
+33 495 Corsica
+33 320 Lille
+33 562 Lyon
+33 491 Marseille
+33 4 Monaco
+33 467 Montpellier
+33 240 Nantes
+33 1 Paris
+33 326 Reims
+33 477 St. Etienne
+33 494 St. Tropez
+33 388 Strasbourg
+33 5 Toulouse
+33 247 Tours
+33 470 Vichy
Jun 09, 2011 | Lands Phones
MITSUBISHI Lancer GLX 1998 Manual transmission...
look for a vacume line broken or rotted off
Jun 11, 2008 | 2003 Mitsubishi Lancer
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
