Question about Skil Standard Duty Jigsaw Model 497 1/3 Hp
Missing saw blade set screw - Skil Standard Duty Jigsaw Model 497 1/3 Hp
My DeWalt DW303 Type 1 recip saw's blade set screw is among the missing. Does anyone know what the thread is for the blade set screw. Thanks in advance.
I think it is not only the thread but also the material its not 8.8 material otherwise its much harder ,use only materials with the same hardness standard steel shall lasting not long its to soft and will come loose By Dewalt nr 099164-06 or a molybdenum steal from everywhere and equivalent hardened.
Mar 25, 2017 | Dewalt Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Blade broken down in jig saw
This may sound to simple and not mean to be funny or insulting but why can,t you just take the screw out that holds the blade in you would have to do this when ever you needed to replace or change to a different blade Idon,t know mabey im missing something that your trying to say im not sure
Dec 04, 2010 | Skil 449501 6 Amp Jig Saw
The bevel on my my ryobi 10" table saw model BTS12S does not change from the knob reguardless of the position of the bevel lock ar regaurdless if i adjust the bevel lock. i just got this saw so i do...
Suspect that a part was left out of the bevel adjust mechanism. Best to take the saw back and get a warranty replacement--let warranty fix the defect. Can you change the bevel of the blade by pushing/pulling the blade? I would suspect a missing worm gear on the bevel control shaft if you can. Otherwise, look for loose/missing set screws on the shaft or possibly a missing key. Good luck!
Oct 30, 2010 | Garden
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0908018-00004.png part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
Mar 19, 2010 | Craftsman 10" Table Saw
Black and decker jigsaw blade comes out during sawing but seems to be locked
Either the blade is not in all the way, or the back plate is missing or screw is stripped.
Oct 23, 2009 | Black & Decker Scroll Jig Saw Blade
Blade Slips Off
The two Wheels must be in line to each other, has one of the wheels moved? Does the missing screw clamp the wheel to the shaft? If yes you MUST replace the screw.
Aug 05, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Skil Standard Duty Jigsaw Model 497 1/3 Hp Logo
37 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
