Question about Frigidaire Washing Machines
Error code 20
This is all that comes up on display panel
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Is it an E20 error code? The E20 error code is usually something clogging the pump system follow these steps to check. From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yes, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside and remove any thing that does not belong, reassemble ant test.
Posted on Nov 25, 2013
I have an electrolux gas range, model ew30gs65gs1. I get error code f14 when I plug it. Clear error code, try to set anything except the clock on the glass panel and o very f14 again.
The F14 error indicates a problem between the touch pad and the display control board. This could be a wiring problem so check the wiring harness between the two parts. Make sure that the wires are properly seated and check for corrosion at the connectors. It could also indicate that either the touch pad or the display control board (or both) are faulty. If your wiring is good, you need to replace the touch pad. If the error persists after replacing the touch pad, you have to replace the display control board as well.
The parts are available here: http://www.searspartsdirect.com/model-number/ew30gs65gs1/1412/0124250.html . See parts 19 and 20 on the control panel diagram.
I hope this helps.
Dec 28, 2016 | Electrolux Kitchen Ranges
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
What does F 20 error code mean?
Thats a code indicationg a bad control panel.
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HP Printer not printing, activated error code -20
Error 20 Memory Overflow / Insufficient Memory
  • A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
  • On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
  • On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
Nov 24, 2009 | HP Office Equipment & Supplies
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Washing Machines Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
