Question about Humidifiers
Yellow light safety first humidifier - Humidifiers
I need help puting the staps back on a safety 1 car seat
Uhm, you're in the Humidifiers section, you may want to move this question to another section...
Apr 08, 2013 | Safety First Safety 1st Healthcare Baby...
No water
well these dont work in winter 1st off if heater is on were u from try to wigle the water buket on it just right so sits in and turns on sum sensor toucjy the way they sit in
Jan 19, 2008 | Honeywell HCM-300T Humidifier
Wiring a generalaire 1042 humidifier to a goodman furnace,when there are no terminals marked hum
24 VAC HUM
The yellow wire connected to the I.D. Blower pressure switch
is powered anytime the pressure switch is closed and provides
24 VAC humidifier control. Remove the yellow wire and connect
the supplied brown jumper wire to the pressure switch
terminal. Reconnect the yellow wire to the "piggyback" terminal
on the brown jumper and then connect the 24 VAC line of the
humidifier to the stripped end of the brown wire. Using a wire
nut or a field-supplied quick connect terminal can make this
connection. The wiring must conform to all local and national
codes. Connect the COM side of the humidifier to the B/C
terminal on the furnace control board (or to the COM side of
the 24 VAC transformer). DO NOT CONNECT 115V HUMIDIFIER
TO THESE TERMINALS.
Feb 21, 2011 | Humidifiers
Does anyone know where i can find a wiring diagram for a model 600 aprilaire humidifier.
I hope this helps.
http://www.aprilairepartners.com/products/category/humidifiers
Scroll down towards bottom of page. I looked under the heading "CURRENT RESIDENTIAL MANUALS", and clicked on "Humidifier Model 600 Series Safety and Installation Instructions Template with Model 60".
Dec 19, 2010 | Aprilaire 600 Humidifier
I was told by the technician tha insalled my funace that I could wire te humidistat to it bu I cant remember what teminals to use the terminals are lettered G W R Y C the thermostat uses W R Which one...
None of these.
Coming off the humidifier you wil find 2-red and 2-yellow (through a plug).
The red supplies 24 volts and is wired to the "hot" and "common" terrminals of an electronic humidstat. (They are NOT used if using a mechanical humidstat.)
The 2-yellow are wired to the "HUM" terminals of the humidstat (either mechanical or electronic).
If you are using a sail switch or current sensing relay, it cuts into one of the yellow wires. (Yellow from humidifier to to humidstat. Then from other terminal of humidistat yellow runs to to relay (or sail switch). Then from other terminal of relay (or sail switch) yellow back to humidifier.
Dec 14, 2010 | Honeywell HE360A1027 Whole House...
How to reset the humidifier when the green light change to yellow ?
You just turn the switch to off and let it sit for a few minutes. Then when you turn it on again it will be green. I turn it off when I take the tank off to fill it and by the time I return, it has reset.
Nov 25, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Humidifiers Logo
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
