Question about Locks & Locksmithing
How to reset an image electronic lock
It says the brand is yililock it must be a Yale knock off
How do I open my Yale Home Safe YSS0000NFP. The batteries have gone totally flat.
Yale battery operated safes have a manual override function for which keys are supplied.
Nov 14, 2014 | Locks & Locksmithing
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
How do I remove the cylinder from a Yale Y130/70/116/1 padlock so I can remove a broken off key.
You can't. Make sure the cylinder is in the upright position, and tap the lock on a bench face down (very hard) it may dislodge it enough to grab it with some tweezers.If no luck, throw it away.
Feb 25, 2014 | Yale Y130/70/116/1 Marine Grade Stainless...
Service manual for yale hsa3800 wireless alarm needed
I researched the model number with no success. I assume that you live in the United States as this is a Britain-based company. So I'm providing you with a link to their US support information:
http://www.yaleresidential.com/en/yale/yale-USA/Contact-us/
and I encourage you to call them directly with your request.
Jul 24, 2011 | Locks & Locksmithing
Hi dear i have lngersoll deatbolt rim lock front of my door. i wanted to replace the only rim cylinder but i dont khow how to remove old rim cylinder. also can i use other company,s rim for my old...
The lock is removed after you undo the bolts on the inside The whole cenre should slip out. I doubt you can use another brand in the rim that will mate up with the equipment inside the house side of the door But you can completely replace it in the alreaqdy made hole
Aug 30, 2009 | Deadbolt PFK Touchpad Electronic Lockset
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
