Question about Sentry Safe Products - Sentry Safe - Combination Home Safe, 1.2 ft3, 16-11/32w x 19-5/16d x 17-27/32h, Gunmetal Gray - Sold As 1 Each - Three-number combination lock with clicking dial and tubular key lock. - Four live-locking bolts. - Multi-position d...
Lost combination to fort knox vault safe with dial combo
Lost combo want to reset numbers. This is a dial combination. Have large plate off inside of door and have exposed it looks like a removeable mechanism for combination. How can I change the three numbers?
joboo1
  • 257 Answers
SOURCE: get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
SOURCE: Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Posted on Aug 05, 2010
  • 42 Answers
SOURCE: I have a Brinks Fire Resistant safe Model number
https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
Contact Sentry. They can give you a default combo so you can reset it and program it with your own and get inside.
Wish you luck!
Posted on Mar 10, 2011
  • 207 Answers
SOURCE: we (or our kids) shut
you need a locksmith...
Posted on Apr 15, 2011
I NEED A COMBUNATION FOR A LIBERTY SAFE I HAVE SERIAL NUMBER
First, this isn't a riding lawnmower!
Second, you need proof of ownership to get a combination from any safe company. Unless the safe is built in to the house which you might have some leeway.
All I had to do is GOOGLE liberty safe and found their website, first thing on the list!
Click on Owner Services and then Combo Vault.
Oct 03, 2016 | Home Security
I have a Sentry 1380. I DO have the combo, but I guess from moving it too many times, It will not open. Any ideas.? Ive tried the combo standard direction and reverse. Thank you for any help.
As a Safe and Vault Tech I would recommend adding or subtracting 1 number at a time to the combination numbers. Just I case the locked got bumped when you moved it . For example if the sentry safe combo was 60-20-40 you would try 61-21-41 or 59-19-39 then try 62-22-42 or 58-18-38 and so on.
Jan 02, 2010 | Sentry Fireproof Safe
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
I got a new Sentry safe. I cant find my instructions but i got my numbers to get in. how do i enter my numbers. its a twist knob.
Safe and vault techs advise
Pull the handle down; cracking sentry safe open.
Sep 28, 2009 | Sentry Fireproof Safe
Need to reset combination
A good locksmith would tell you all you have to do is line up the notch in the tumbler wheels with the bolt bar. Turn the dial three times to the left and line up the first notch with the bar and note the number. Then turn the dial 2 times to the right to line up the second notch note the number. Then turn the dial left to the last notch note the number and turn the handle to retract the bolts. This will be your sentry safe combination. To dial the safe open see these opening instructions.
May 18, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
Sentry Safe Products - Sentry Safe - Combination Home Safe, 1.2 ft3, 16-11/32w x 19-5/16d x 17-27/32h, Gunmetal Gray - Sold As 1 Each - Three-number combination lock with clicking dial and tubular key lock. - Four live-locking bolts. - Multi-position d... Logo
87 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
