Holmes heater HEH2998
Keeps shutting off, blew dust out of it with hair dryer on cold, it had lots of dust. Runs for 5-10 min then shuts off.
5 Suggested Answers
SOURCE: keeps shutting off
I have a LASKO 5565 model fan and had a similiar problem. Cleaned the whole unit, thinking it was tripping the safety breakers, and it still would turn on and off. The control console was completely unusable. So then I thought that it was maybe the squat switch located on the bottom of the unit. I quickly deduced that not to be the problem and continued following the wiring. Just above the fan there is a 1/2"X1/2" thermostat. Upon touching it I almost burned myself. For some reason the unit was grounding here and cause the thermostat to heat up and shut the unit off. I took the thermostat out of the equation and the unit works great.
CAUTION: If you pursue this action you must understand that you no longer have a thermostat and the unit is now simply just a heater. It will either be on at full blast heat or it will be off. Good luck.
Posted on Nov 20, 2008
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
SOURCE: control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Posted on Apr 19, 2009
  • 193 Answers
SOURCE: look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Posted on Sep 28, 2009
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Model md200tbe shuts off, pilot and burner
1) Try blowing it out with a hair dryer. Dust does lots of weird things to gas heaters.
2) There is a thermocouple that opens when it is hot and makes the gas keep flowing. It is a small metal tube that sits directly in the flame. When it heats up, the gas flows. If that is shot, then it won't keep the gas flowing, so it will turn off when you let go of the button. Try tapping it lightly with the tip of a screwdriver to knock it loose. There is about a 10% chance that this might fix it temporarily until you can get a new one.
Mar 22, 2012 | Blue Flame Heating & Cooling
HCH6150 heater runs for a bit and then just stops
Open it up and clean with an air can, most common cause is due to overheating.
Dec 17, 2011 | Holmes Products HCH6150-U Ceramic Compact...
My Sony CS11 keeps shutting down randomly. Please
There's a very good chance it's a thermal shutdown, caused by dust, lint and hair clogging the heat sink. If you have a can of compressed air, blow some in where the warm air comes out on the laptop (do so from a few inches away at first and see whether dust starts coming out of the fan at the bottom, so that you don't force dust deeper into the case). You may be able to remove most of it that way. I also masking tape a square of used clothes dryer fabric softener sheet over the fan intake once it's clean (don't cover it with tape) to filter out dust and especially lint and hair - change it when it looks dusty. It really helps.
Oct 26, 2009 | Sony VAIO VGN-CS110E/Q Widescreen Notebook...
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
