Scan in color
How can I scan in color? Lanier LD232c
Press the "Scanner" button. The new screen includes a button for "Scan Settings". Press that button; the next screen offers, among many options, a pair of buttons for "Tex/Photo" or "Full Color". Make your choice, then press "OK" and you're back to the main scanner menu and you scan as normal.
Everything is easy, when you know how. <s>
Frank
Posted on May 08, 2009
How do I adjust print margin in service mode
I figure it can be done on the computer settings for the printer.
Jul 16, 2015 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
Ld238c replace fuser
Its a maint. light, no need to replace unless quality problem. -Carl
Mar 22, 2014 | Lanier Ld228c Ld232c Ld238c Copier Fuser...
When I copy, document comes out backwards
hi you need to press the 123/user button on the top left of the display this gets you into setup press for the copier and here you will see the sections for paper and default setting you are looking for the duplex it will be set up tor top to top or top to bottom see which it is set on and change it to the other setting
Jul 08, 2010 | Office Equipment & Supplies
Put the last page in first and the first page in last.
Jul 08, 2010 | Lanier UNKNOWN
Scan routing
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/x22_27/x22_27en.htm
Go to the above site and download your software and a manual, the manual tells you exactly how and what to do.
May 21, 2010 | Lanier 5222/27 Laser Printer
How do I clean the transfer belt on my Lanier LD232c (same as Ricoh Aficio 2232)?
The transfer belts on these generaly cant be cleaned if you know how you can just remove the transfer belt unit and take the cleaning unit ou this is positioned on teh leaft hand side just under the belt at the top there is screw take this out then press the small brown lever and and pull teh unit out carefully make sure you press the lever in as jif you dont you can damage the belt..vac this out and wipe the blade with a soft dry cloth.. if you are savy with the machine the main area to clean is the alloy or chrome roller at the top.. you will have to take the belt off to clean this.. the id sensors read off this to get reg and colour calibration right so it coulld cause problems if this is dirty..let me know if this helps or if you need more info..Good Luck A
Jun 29, 2009 | Lanier Office Equipment & Supplies
Lanier copier won't scan to computer
IF you're scanning to folder, check your security settings in file sharing. Try allowing all permissions to each listed and apply.
If you there is a computer that you know definately works already, have a look at their settings in security tab of file sharing - and change permissions to allow full control (for now). See if your scanning works.
Oct 24, 2008 | Lanier Cquence M3
88 people viewed this question
k24674
jasbo
jasbo
