Question about Samsung Washing Machines
7.5 kg SW75V9W
Loads of black bits and some large bits of black , don"t know what they aRE. Not stuff from the catcher at all , getting worse, What the Hell is it ????
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: When machine spins after wash
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Posted on Aug 18, 2011
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
Where do i find the pump filter on a g eenergy star front load washer
mine was behind the lower panel, which is underneath the front door.
it comes off with 3 screws, right along the bottom edge of the machine.
the filter itself is a large, circular nylon plug, that unscrews quite easily. quite a bit of water will drain out of there, so have a bucket or basin handy, and don't panic - if there's too much water coming out, just screw the plug back in.
just to be pedantic, i put a black mark on the plug and on the housing, so i would know how far to tighten the plug when i put it back. (it's not good to over-tighten plastic parts.)
Sep 17, 2011 | GE Energy Star WCVH6260F Front Load Washer
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
WHERE WILL I GET LG KG195 PC SUIT
Here you go dear friend :
http://lgmobiles.com/index_gsm.php
Just select your handset model and download the PC Suite for your handset.
Hope this help.
Jun 06, 2009 | LG KG800 Cellular Phone
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you...
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Apr 16, 2009 | Okidata 320 Turbo Printer (Remanufactured)
I want to know about virus free LGkg 195 softwares
hey there.... i think i might just be able to help you here......
please visit www. mobile9.com       for your mobile content....
you will get most of stuff there....this should help......
PLEASE REPLY if you don`t get any thing good from this.....
AND PLEASE VOTE......HELP US TO HELP YOU BETTER..
Feb 20, 2009 | LG Shine KE970 Cellular Phone
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
