Question about Eaton Outdoor Non- Metallic Fusible Air Conditioner Disconnect 30 Amp
How to replace an Eaton 60 fusible pullout a/c disconnect
When replacing fuses, do the fuses have an up or down? The 60 amp unit came without fuses. I assume it takes two 30 amp fuses?
    Genius:
  • 1,198 Answers
There's usually a physical size difference between 30 and 60 amp fuses, so whatever fits. Either end up.
Posted on Nov 26, 2013
What guage wire for the black fusible link?
There should be 2 white wires coming from the alternator. There is a splice where it will go into 1 wire then into the fusible link. If the fusible link is not burned, simply match the gauge wire coming from it. You should never use anything smaller in diameter than 10 gauge wire for the charging system. If you want to replace the fusible link, you can run separate white wires from the alternator to the positive battery post with individual fuses or fusible links. I would recommend each wire have its own Maxi fuse holder with a fuse no less than 60 amps each.
Aug 10, 2012 | 1989 Nissan Pathfinder
How to hook up wires
you will need a 10 -3 wire hook up the red and black to fuse netral and ground to the ground should work
Aug 03, 2012 | Electric 30 Amp Fusible Indoor Safety...
I have a Eaton-Cuttler-Hammer 60 Amp fusible Pullout Disconnect for my house AC unit. When the weather gets warm and the AC runs alot, one, or both, of the fuses blows. The plastic panal inside the metal...
Does not matter which way the fuses go....
The contacts are bad and will cause the fuses to blow sooner because they are heating up...
It will not cause a fire, but you should have the disconnect replaced or you will have continuous problems...
heatman101
Jul 10, 2011 | Heating & Cooling
1984 Chevy 350 has two fusible links,one foe ignition the other for headlights which is blown. Can I replace with a blade fuse and what amperage is equal to the wire gauge that is on the original?
Fusible links work much differently than blade fuses, they can tolerate a large load without melting, this is why they are used for high amp draw systems. You can't substitute the blade fuses, they will blow repeatedly if you do. Fusible links are very cheap and all auto parts stores have them, they go by color to indicate what the amp rating is, wire gauge is not used. So the bottom line hear is you can use blade fuses but they will likely blow often, you will need fusible links (Green) or 30 or 20 amp fuses. Here is the color breakdown of all fusible links.
BLACK 45A
RED 35A
GREEN 30A
BROWN 20A
May 24, 2011 | 1984 Chevrolet K1500
Is the fuse in a powerware 9135 user replaceble
There are numerous fuses (rectifier, inverter, charger, battery) on the 9135 that are located internal to the unit and not readily accessible to the user. Generally a blown fuse is accompanied by another component failure which caused the fuse to blow in the first place. As a result, additional troubleshooting and testing is usually required to identify the root cause of the failure. This of course leads to soliciting the services of a technician who has access to the schematics, test equipment, and parts to initiate a repair. Without the schematics, it's like working in the dark. For complete support, please contact Eaton (Eaton bought Powerware so now it's the Eaton 9135):
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
www.eaton.com/9135
Jan 05, 2011 | Eaton Powerware 9135 UPS (700465446) UPS...
96 buick century - lights/brake lights/dome lights, etc not working. have tried replacing several fuses and a circuit breaker in fuse box in glove compartment. is there another fuse box under the hood?...
Check fusible links coming off of the starter, with the battery disconnected.
Pull on the various colored wires that have a barrel of foam on them about 1/2" to 2/3" long that indicated that the wire is a fusible link.
If a fusible link stretches, the inside of it is blown. Many circuits can be controlled by the fusible links.
REPLACEMENT
Fuses protect all the major electrical systems in the car. In case of an
electrical overload, the fuse melts, breaking the circuit and stopping the flow
of electricity.
If a fuse blows, the cause should be investigated and corrected before the
installation of a new fuse. This, however, is easier to say than to do. Because
each fuse protects a limited number of components, your job is narrowed down
somewhat.
Fig. 1: Fuses come in different colors which indicate different
amperage ratings
The amperage of each fuse and the circuit it protects are marked on the fuse
box, which is located under the left side (driver's side) of the instrument
panel and pulls down for easy access. To replace a fuse, simply pull it from the
panel. Insert a new (same amp rating) fuse in its place.
Nov 03, 2010 | 1996 Buick Century
Hi, I have the Cutler Hammer fusible ac disconnect 30 amp, my question is with the 10-3 wire from the fuse panel to the pullout do you only use the Black White and Ground and lay back the Red? Also, can...
If you use a white wire to carry a 120 Volt line it would have to be taped with either black or red tape both at the breaker box and your fuseable disconnect so the solution is to use the black and the red wire into your curcut breaker, the white and the bare ground both tie into the grounding post at the circut box and at the fuseable cut off, Yes the fuses are neccisary per code.. to eliminate a short or fault from traveling all the way back to the breaker box.. often times found inside the building the fusible pullout is attached to. check your local codes and regulations for more specific details.
Aug 09, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
I reversed the cables on battery and now the truck will not start
Look for a blown fuse,or fusible links to be burned out,these fusible links will bolt onto the starter with the positive cable,I do not know what year it is,but if it is a newer model,there is a fuse on the rail,on passengers side,near the radiator,it will be a flat fuse with two mounting bolts on each side of it,150 amp,or 200 amp,or lower,disconnect the battery before replacing it.
May 10, 2010 | Chevrolet C1500 Cars & Trucks
I purchased a 60-Amp Cutler-Hammer Fusible Pullout Air Conditioner Disconnect to replace my older (over 20 years) one for my AC/Heating unit inside the house. Looking for a wiring diagram as I have 2-wires...
The two wires coming from the breaker box go to the terminals marked "LINE". The two wires going to your AC unit go to the terminals marked "LOAD".
Hope you find this to be very helpful. :-)
Mar 22, 2010 | Heating & Cooling
Wire diagram for fusible pullout a/c disconnect.
THERE IS ONLY THE WIRES GOING IN AND THE WIRE GOING OUT THAT IS HOW THIS WORKS
Jan 07, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
Eaton Outdoor Non- Metallic Fusible Air Conditioner Disconnect 30 Amp Logo
78 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
Vuk B
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
