Philips lcd 32pfl3514d f7 no power up/no power led
No power/ no power LED what are the known problems with this lcd tv
ginko
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
dsacco86
  • 1077 Answers
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 15, 2009
roety
  • 585 Answers
SOURCE: Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Posted on Aug 17, 2009
  • 8457 Answers
SOURCE: I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Posted on Oct 22, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 30, 2015 | Philips 46PFL5706 - 46" LCD TV -...
Philips 46" 46PFL3608/F7 wont power on, no flashing LED nothing just a beeping coming from the power supply board.
HI,
first of all connect the tv to another power outlet in you home. If then also its showing the same problem Probably the power supply broad would be faulty. you have to check the power supply. if you are able to do it then this video will help you know hoe to check the power supply.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Sep 22, 2015 | Philips Televison & Video
Why my 42pfl5907 tv will not turn on?
Plug it in.
Check your internal fuses.
Then check the power cord for continuity.
Nov 01, 2014 | Philips 42PFL5907/F7 42 Class Led Lcd...
How to fix 40pfl4908/f7 will not turn on
My philips tv no 40pfl4908/f7 has a white flashing light and the tv does not turn on
Mar 15, 2014 | Philips 40PFL4908/F7 - 40 LED 1080p HDTV...
Hi! I purchased the philips LCD at Florida, then 2 months after i bought it, it suddenly won't work, it has power but only black color appears on the screen...I wont be able return it from the store where...
Ur tv dosen't work in the Philippines,because tv used different signal frequence in ASIA tv signal work only as PAL frequence only.The tv u bought in the US work only on frequence call NTSC so it will not work in ASIA.
Apr 14, 2011 | Philips Televison & Video
I have a Phillips LCD tv model# 32pfl3505d/f7 after about an be it shuts off by itself. Can u help me please
Hello; there is some confusion with your model # and symptom ! A model# 32pfl3505d/f7 is a 32" LCD TV not a 27" After WHAT does it shut off? This seems very similar to a set I just repaired. My customer's set was a mode l# 32pfl3514d/f7, which may be same or similar to this one. Here is what happened ; The set would run for about an hour and shut off and come back on repeatedly. The problem was a bad digital board ( the one on the lower left side with all the jacks as you face the back of the set ). I found this $150 board on EBAY for $33. He still has about 30 of these boards. You probably have the same set and same problem. John
Dec 19, 2010 | Philips 27PT643R 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
