Question about Jet JPM-13CS, 13" Closed Stand Planer / Molder, 1-1/2HP, 1Ph, 115/230V
Board is stuck in planer and I can't get it out
I was planing a board and it got stuck. I cannot move the table up and down with the handle. It is really stuck tight.
    Genius:
  • 1,198 Answers
Unplug the power cord. Then rotate the motor backwards until the board is free. It will take a lot of turns for the unit to free up. Look at the blade to make sure you are rotating the motor backwards.
Posted on Nov 26, 2013
Why does it snipe?
Contact the place where you bought it and ask them, or ask the manufacturer.
Aug 19, 2014 | Craftsman 1212 in Thickness Planer
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
Table on jet planer will not lower and board is stuck
Unplug the machine, and rotate the motor backwards. Look at the cutter to determine you are going backwards. Eventually things will free up, but it will take a while. Then clean out everything real good, and keep it clean. Consider a shop vac hooked up to a discharge if it has one.
Nov 25, 2013 | Jet JPM-13CS, 13" Closed Stand Planer /...
Severe sniping with planer
You will always have snipe at the end of planed boards equal to the distance from your infeed and outfeed rollers. It's severity is determined by how much the board sags or dropps behind the planer until the second roller catches the board. Some planers have extended tables to help with this. What you can do is hold the board up as much as possible and still let the infeed roller move the board smoothly until the board contacts the outfeed roller.
Jan 30, 2013 | Craftsman 12 amp 12-1/2" Bench Planer...
2030 power planer table moves, changing cutting height.
put a lock nut on the thread
after adjusting the height
lock the thread with the lock nut
Dec 02, 2017 | Makita Planer-Jointer M-2030
Delta tp 305 is sniping wood at both ends , is there a solution to this problem?
With any of these portable planers, the sniping can be a problem that you can minimize. Of course you can use a board longer than you need... but more practically: 1. Take light cuts 2. Make sure your infeed and outfeed tables are at the same height and are parallel to the suface of the machine below the cutter. 3. Provide additional in-feed and out-feed support beyond the little in-feed and out-feed tables to keep your material moving consistently in the same plane from start to finish. you might use support rollers. Take care to get the whole setup adjusted all in one plane. Good luck.
Oct 16, 2012 | Delta TP300 Shopmaster 12-Inch Portable...
WHEN PLAINING A BOARD IS COMING OUT WITH A UNEVEN PLAINING ON THE ENDS OF THE BOARDS ABOUT 3" TO 4" FROM THE EANDS.
this is normal with all planers, when you feed the board in the planer there are two feed roller one on each side of the knives so you get uneven pressure on the board at the start and at the end of the board .when planing boards for a project always add 10"inches or more extras then cut to lenght after planing to thickness required. never cut boards to length before planing .
Apr 11, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
The planner nips the end of the board
My planer does the same thing.
1) I don't make the final cuts on my boards until after planing.
2) I discovered why the planer does this. I don't have a planer table. I use the two metal stands that came with the planer, and they don't really hold the board flat & steady like a planer table would. The planer has 2 rollers >>> one roller is on the feed-end and one roller is on the finished-end. When the end of the board goes past the feed-end roller, it is no longer held flat by two rollers. The weight of the board causes the board to tip up into the planer blade on the last 3 inches. So sometimes I just hold up the end of the board as it finishes ... but it still takes a nip out of the board now and then.
Up-vote if the information helped you. Thanks for the feedback.
Oct 15, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Planed board has a lower step than the rest of the board after passing thru planer , not equal amount planed off.
I think you are talking about what is commonly called "snipe". This is an inherent problem with all planers, but especially with heavier cuts. You can take lighter cuts, or you can start with a board longer than your intended finish length. You can also put the board you are planing on top of a longer board, then feeding them through together.
Sep 02, 2010 | Ryobi Thickness Planer Blades
Planes Comparison
If you have a stack of hand planers and you do a lot of woodworking, you might want to buy a power planer. Power planer have a number of qualities that should convince you to keep the old hand planers but add that power to the group. Choose a power planer when you have a lot of planing to do. One thing about a power planer is that it is much faster compared to the hand planer. Use a power planer when you need to make rabbets or even scrolling. The power planer can do both of these jobs. There is a great deal of versatility about a power planer. Keep the cut smooth with a power planer. Frequently a hand planer needs to be lifted and started again. This leaves gouges and groves. A power planer has a continuous blade that leaves a smoother cut. Get more precision. The continuous motion of the hand held power planer and set depth cuts the specific amount that you want. Plane larger areas. You can plane doors quickly and easily with a few strokes of the power planer. Straighten a board easier with a power planer. You also can create chamfered surfaces with the power planer.
Aug 27, 2008 | Rockler Carbide-Tipped Radius Plane &...
Jet JPM-13CS, 13" Closed Stand Planer / Molder, 1-1/2HP, 1Ph, 115/230V Logo
48 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
