Question about LaCie d2 300979U DVD±RW Dual Layer Burner
Parts can you help me to where i can get spare cords for the machine. i need the acutual adapter with the cord fixed onto it
  • 27 Answers
Just go to ebay you can find it there and if you cant just call the manifacter of the machine and iam sure youll be able to buy the part there
Posted on Oct 10, 2007
SOURCE:
Where can I purchase the power cord for the mighty menders sewing machine w100.. I got a used one but without the power cord
This is a bit unusual as it appears to have a power adapter a bit like a laptop. It you have the adapter, any good electrical shop will have the cord to it.
Product description If you are looking for a lightweight, portable, compact sewing machine for those everyday mending and sewing tasks, the Mighty Mender is it! This handy little machine offers important features such as free arm design, true locking stitch, 2 straight stitch lengths, built-in bobbin winder, drop-in bobbin, foot controller and more! It is easy to operate because of it's compact size, it can be used anywhere and conveniently stored when not in use. Crafters and sewers alike will find 100 uses for the Mighty Mender WW100. Accessories included are: an electric adapter, instruction manual, needles, bobbins, needle threader, and seam ripper.
it is pretty obscure
mighty menders w100 sewing machine spare parts Google Search
Jun 04, 2018 | Sewing Machines
How to replace power cord?
Replacing a power cord is fairly straightforward for those who already have a little experience.
The power cord is either obtained as an assembly as a spare part for your machine or bought as a simple length of cable from the local hardware or electrical shop. If the strain relief grommet is moulded onto the cable an assembly will probably be needed.
Carefully removing the existing lead will provide a pattern with the correct dimensions to cut the replacement, remove the insulation, etc.
Appliances use a variety of methods of connecting the power cord into the internal terminal block but which screws to remove is usually an intuitive process.
Jan 23, 2016 | Food Mixers
WHERE CAN I BUY THE PART TO FIX A COMPAQ LAPTOP PRESARION WM-419? IT IS THE PART THAT THE POWER CORD INSERTS INTO
Melinda:
From your description there could be two different parts, one would be the power adapter that the AC power cord plus into, or the other would be the connector on the laptop where the DC power connects into.
You can buy either of these on ebay. Just search Compaq Presario 700. There are several power adapters and there are many parts machines that you can cannibalize the power connector.
Aug 28, 2011 | Compaq Presario 700 470024-192 Notebook
I need an adapter cord for AC power
You will get to buy the ac adapter cord from any electronic spare parts shop. Please ask for the sony cord which is usually one with a ridge on either side of the plug in. It made by many manufacturers and may not be difficult to get.
Good day
May 28, 2010 | Sony Audio Players & Recorders
Inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Need to change electrical cord on g5 kirby
This should be fairly easy to do. With the cord unplugged, take the screw out that it holding the hard plastic cord cover onto the base of the machine. This is where the cord looks like it's going into the bottom of the machine. The next part is a bit tricky. The hard plastic piece holding the cord in can be popped out with a flat head screw driver. On each side of the cover pop the tip of the screw driver into the side and gently pull to the side. Do this on both sides of the cover and it should come right off.
The cord should just pull out.
Put the new cord in, pop the plastic cover back on, and put the screw back in.
Let me know if you need more help.
Aug 19, 2009 | Kirby G5 Bagged Upright Vacuum
Samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
Apr 17, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
Power cord
I checked your monitor and judging by the picture, it requires an specific ac adapter. see photo below to see if this is what you see:
2edb0f8.jpg I show the spare part for this ac adapter is 308573-001. it runs approx $45 on google. Hope this helps.
Jun 08, 2008 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Power cords
Is it too late?
From the HP support:
Power specifications
. Power consumption: 50W maximum
. Source (Input) Voltage: 100 to 240 VAC*, grounded
. Input Frequency: 50 to 60 Hz
. Current: 1A maximum
* Figures are based on using the AC adapter that came with your unit (HP part number 0950-2880)
Don't know if you can get an adapter, but at least you have a part #.
Dec 10, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
It won't charge
i had the same problem and noone was able to help me "shame"
so what i did is.. open the base "where you place the machine for cordless charging" then get the adapter at the end of the cord there is the connecting part "input" the one u stick it in the machine's *** for corduse cut that part "input" from the adapter and you connect it str8 to the base "inside" and i promise it will work.
mine working now cord/cordless
PS: to keep using it cord buy another adapter and cut and connect and keep yours for cord use!
hope i'm more useful then the people runing this show.
Oct 16, 2007 | Vidal Sassoon VSCL870 Hair Trimmer
Open Questions:
See all LaCie d2 300979U DVD±RW Dual Layer Burner Questions
LaCie d2 300979U DVD±RW Dual Layer Burner Logo
69 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
