Question about Zenith VRC420 VCR
Correct cords i'm trying to hook this VHS player to my little old tv and i don't know if i have the right cords or if it needs more than the one red/white/yellow cord that i have. Halp?
  • 24 Answers
Does your TV have connections (RCA plugs) on the back somewhere? If not, you need an antenna connection from the screw-on connection on the back of the VHS unit to an adapter to your VHF antenna screws on the TV unless your TV is new enough to have a screw-on type cable for the antenna connection. The tape player will broadcast a signal right into your TV over channel 3or 4! Check a TV sales department or Radio Shack for the parts.
Posted on Nov 25, 2013
I have a sanyo vhs and recorder cords are correct in tv and vhs plays sound but wont show picture on tv tried different cords tried cable cord was working then all of a sudden quit what can i do
vhs either has the picture circuit out or the heads are way too dirty to work. you can clean the heads on these it is pretty easy, if you would like to know how you can let me know.
Nov 05, 2015 | Sanyo Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I am trying to watch all my old Disney tapes with my little sister but we cannot get the VCR hooked up to the TV. Our TV is a Zenith and it is in a large, all-wood entertainment center/cabinet. I just need...
Ur tv have a Video output holes like Video IN Y,R,W.Used a RCA component cable like Y,R,W connected Y,R,W IN holes for the tv and the other end of cable out for VCR OUT input holes,now VCR player will play VHS tapes.
Jun 02, 2011 | Mitsubishi HS-U747 S-VHS VCR
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
VHS to DVD
I just bought at Best Buy the Samsung DVD Recorder & VCR. You can copy your VHS tapes right to DVD and or hook up an external source into the deck and copy them to DVD.  I find it working well but many of my tapes have tracking issues which is becoming a hurdle for myself.
Apr 22, 2008 | Samsung DVD-V4600 DVD Player/VCR
I cant get aux on my symphonic tv to play
Try Channel down from 2 or up from 99.......T.
Jan 22, 2008 | Televison & Video
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
CONNECTING HDMI CABLE
The HDMI cable plugs into the TV and other sources. Make sure you have the correct HDMI cable for your set. Each cable handles both audio and video. Turn it over if it does not fit in. It only fits one way.
You need one cable for each source and your TV has to have at least one jack for each source or you need to buy a switch box, if it has only one and you have several. You then must select the correct source on your TV for the input. Your satellite box (DVD or VHS) each must have a HDMI jack to use this cable on each.
Let me know how you make out.
Dec 15, 2007 | LG 32LX3DC 32 in. LCD HDTV
Televison & Video Logo
47 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
