Question about Freezers
Kenmore model 32205
What year is this model
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Aug 15, 2015 | Kenmore Freezers
I have a kenomore freezer model 19502
In a situation like yours, the freezer comes with a 1 year warranty covering all parts and labor from the manufacturer. On the machine where the model and serial nimber are located there is also a nunmber to call for service. If you can't find the number google the number to whirlpool, who makes kenmore.
Apr 23, 2012 | Kenmore Freezers
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Are all kenmore freezer keys the same are they generic for all
There are 2 different types. You can find the correct only with a model number or borrowing a key from someone with an older freezer like yours. Eric
Aug 31, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
48 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
