Question about Raritan Icer-ette Ice Cube Maker
When I turn on the unit, the icemaker gets warm, but nothing else happens. Ice is not made and what minimal sound is heard, stops after about 3 min.
    Problem Solver:
  • 9 Answers
It needs freeon
Posted on May 23, 2009
  • Rcollilu May 12, 2011
    What psi should the suction line be while in operation
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    This frigidaire (side by side) only blows warm air on both sides
    Good day,
    First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
    Sounds more like starting components on the compressor, or a compressor starting to fail.
    Post back with results.
    Thank you.
    Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
    Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
    I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
    Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
    May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Starts to make ice, but goies in reverse cycle before finish
    OK. Forget the board. what you hear is the pump running when the unit is off. It sounds like a drain is kinked and the pump is shutting it down for safety.Also when this unit starts it will dump early for a couple of cycles before the ice gets normal size. Run the icemaker and unplug the pump in your water trough to make sure it has a frost pattern all the way thru.(takes 5 min)If not it could be a leak it the sealed system. Remember when you adjust the setting on the board this will take 5 cycles before you see any changes. And 24 hours for more consistant ice.
    Mar 26, 2009 | U-Line Icemaker
    Ice maker not turned on or hooked to water line
    it my be not the icemaker check fan or you can remove icemaker
    Feb 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Standalone icemaker sounds like a Harley Davidson
    check and make sure you don't have a piece of scale in the intake of the waterpump. the pump stops when the unit goes into defrost to dump the ice onto the cutter grid. also check the fan under the icemaker for lint buildup on the condensor
    Dec 19, 2008 | U-Line Icemaker
    Ice Maker Not Making Ice BUT making a "trying" sound
    Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
    Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
    Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
    Refrigerator is making a loid noise
    ** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
    Mar 10, 2008 | Refrigerators
    Whirlpool S/S Ref with Ice in Door - Mod # ED5FHEXMQ
    Most fridges run a defrost cycle 2 or 3 times a day. When this is happening a normal pop and sizzle sound will be heard. Otherwise I will need more information. Ice makers need to be cold enough to dispense ice, but not to fill. If yours will not fill, it may be the water filter.
    Feb 20, 2008 | Whirlpool ED5FHEXMQ Side by Side...
    Firgidaire FRS20ZRG Side by Side Refrigerator/Freezer Ice maker not working
    reach into the icemaker and with a finger pull up on the ejector blades on the icemaker watch the blades and see if they go all the way around
    Feb 13, 2008 | Refrigerators
    Raritan Icer-ette Ice Cube Maker Logo
    288 people viewed this question
    Top Raritan Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Raritan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
