Question about Connex 3300 240-Channels Base CB Radio
My tempo one radio will not key up - Connex 3300 240-Channels Base CB Radio
  • 141 Answers
Bad microphone wiring or radio needs repair
Posted on Nov 26, 2013
My factory stereo wont come out of mt 91 Tempo. I have the ford radio removal kit (the U shaped tools). Its completely stuck and wont budge. It doesn't even feel like there's anything holding the radio on...
hi there is a knack to doing this..when you insert the keys into either side of the stereo, make sure when you pull up..that you are also pulling outwards at the same time, this then pushes in the locks that hold the radio in...hope that helps
Jan 06, 2011 | 1991 Ford Tempo 4 Door
I need a key for my tempo 920t please help
I have looked all over online for you and there isn't a place that directly sells the replacement keys. However you can call Tempo Fitness directly and have them send you a key, you may need to purchase it from them, but as you are probably aware you need the key to get the machine to function, so you definitely need the key. Give Tempo a call at 1-866-99-Tempo, they are only open 8 AM to 5 PM Central Time though, so you will need to call tomorrow.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 19, 2010 | Horizon Fitness Tempo Fitness Treadmill...
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
91 Ford Tempo - New stereo won't work ... Please HELP
here is the radio's wire color diagram, u should be able to fix the problem with this info.Fuse box is on drivers side under the dash.
1991 Ford Tempo Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Apr 12, 2009 | 1991 Ford Tempo 4 Door
Trouble Replacing Car Stereo in 1991 Ford Tempo
until u get the hang of it the spring release tools are hard to use, but once u see what makes the spring locks release they are easy the next time. GOOD JOB!!!!
Apr 11, 2009 | 1991 Ford Tempo 4 Door
Need a stereo wiring diagram for 1994 Ford Tempo.
1994 Ford Tempo Car Stereo Wiring Diagram
Mar 25, 2009 | 1993 Ford Tempo
Sideband freq
That is wrong , I used to have a freq. counter that only read when you applied RF to it on my old Tempo rig and I ran lower 37 and upper 35 so I would key the radio on am and tune the vfo to that frequency and would be on frequency with everone else,I remember hearing that once long ago but it's not true.
Feb 21, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Wiring harness cut 93 tempo radio need wiring colors
a quick and easy solution would be to run your own power leads and just use the speaker ...i would suggest using a multimeter
Aug 31, 2008 | 1993 Ford Tempo
Connex 3300 240-Channels Base CB Radio Logo
23 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
