Question about LG 47LD500 47" LCD TV
Lg 47ld500 no pwer no led light red or green ?
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
LG 47LD500-UA CANNOT GO ON ANYMORE THERE IS POWER IN THE CORD WATH IS WRONG
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 30, 2014 | LG Televison & Video
How to repair LG TV
The power supply may have failed.
Nov 07, 2014 | LG 42LM3400 42" LED Cinema 3D HDTV w/ 4...
I have an LG LCD 55 inch model number 32LD400, 42LD400, or 47LD500. Not sure. Problem is I can get sound but no picture. I think it may be my cable box but cable company is saying its probably my tv. The...
You haven't given more details about the state of screen you see. If there is proper back light, there should be a screen displaying LG logo. If this is not present, the back-light inverter board to LED back light board should be checked. http://electronicshelponline.blogspot.com/ If you wish to get more details about back-light fault to LG brand TVs, check the above link. Pull up older posts.
Jun 15, 2013 | Televison & Video
Power on but not functionality
Power meaning light green on or amber or red, If green LED on then check with a flashlight 2 in, away from screen to see if there is a picture on, if so it';s the inverter board.
Dec 18, 2010 | LG 42PJ350 42 in. TV
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
LG 47LD500 47" LCD TV Logo
65 people viewed this question
Computer Repairing
Computer Repairing
