Question about Kenmore Energy Star 44092 Front Load Washer
My kenmore 417.44152400 won't start
My lock button is on and i cant get it to go off
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Remove the screws on the back of the top plate, slide the cover back and lift it iff. You should be able to reach down and manually unlock the door. Also, check the wire on the door look to be sure they are making good contact. If problem persist, replace the door lock. Here is the part to order. Here is a video to show you how to make the repair.
Posted on Nov 25, 2013
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
Controls locked on washer and cant unlock them
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 15, 2010 | Maytag Washing Machines
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
65 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
