Question about Coffee Makers & Espresso Machines
Caffitaly com Hi My dispensing spout seems to be blocked, how do I unblock it?
3 Suggested Answers
  • 102 Answers
SOURCE: facebook.com was blocked.how can i unblock this
The site is working fine.I think your network is blocking the site.Try accessing facebook website with proxy sites below
1.www.hidemyass.com
2.http://www.anonymizer.com 3. http://www.wujie.net
4. http://www.ultrareach.net
5. http://surfshield.net
6. http://www.guardster.com/subscription/proxy_free.php
7. http://anonymouse.ws/anonwww.html
8. http://www.browser-x.com
9. http://www.spysurfing.com
10. http://www.xerohour.org/hideme
Posted on Mar 05, 2010
toac990
  • 838 Answers
SOURCE: how to unblock facebook
User VPN or proxy to unblock the site....
Posted on Jul 20, 2010
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
Saeco Odea Giro nozzle blocked.
First, I'm Not a Saeco Representative, though I have worked on some Saeco machines.
** Most cases of one side not dispensing coffee is usually coffee that has dried and built up over time to coat the least used spout. This is caused by the machine not being flushed or cleaned daily.
** Follow the MFR's daily cleaning instructions to keep you unit operating properly.
** fill a glass up of water to the rim and place on drain tray. the water in the cup should be even with the glass lip all around the cup. If it's leaning to one side then your machine (or table it on) needs to be level in order for the spout to dispense evenly. Another way to check is to place 2 shot glasses under each spout and brew a double shot. Both should fill at the same time and be the same amount when finished.
** Check your MFR's kit to see if there is a small brush to allow for nozzle cleaning. Otherwise follow the cleaning instructions and do multiple cleanings to get rid of the coffee residue. Once cleaned you need to maintain a regular cleaning schedule.
** There are no serviceable parts in these small home machines. Suggest contacting your vendor or Saeco for service or replacement.
Aloha! ukeboy57
Dec 21, 2017 | Saeco Odea Giro Plus Coffee Maker
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
My capsule / pod holder is broken. Where can I get a new one, and how much do they cost ? Thank you
hi,
contact ylavoie@sybco.com. they are located in canada and are the distributor for caffitaly. they have a model called ocs3000 that has exactly the same capsule holder.
ciao
Sep 26, 2010 | Gaggia Caffitaly K111 Coffee Maker
Dishwasher won't drain or seems to drain to other diswasher.
possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Apr 27, 2010 | Fisher and Paykel 23 in. DD603H SS...
Kwc kitchen soap dispenser wont work
Sorry but you need new one, the cheapest I have found is KWC America 504 938 000 Primo Lotion Soap Dispenser on amazon. I hope this was helpful, cheers
Feb 16, 2009 | Delta RP1001-BL Classic Kitchen...
Charmaine
Seems like your school dont want you using Myspace ! hah,
There are 2 ways to usually get around schools very cheap security measures.
Using a proxy server to get around the block (quite advanced)
Or for an easier time, try using a website anonymiser. basically this website enables you to surf the internet on most pages, whilst the anonymiser tricks the internet and the security measures by showing that you are on a legal unblocked website.
their are a few Anonymisers that are useable, whether the school security blocks them or not is unknown here are a few :
www.anonymizer.com/
www.anonymouse.com/
http://www.freeproxy.ru/en/free_proxy/anonymizer.htm
Oct 28, 2008 | MySpace Social Network
Blocked coffee 'spout'
you have to remove the piece with hole in it you got 1 side that block if you dont whant to remove try with steel wire pass that in the hole it should unblock cheers
Jan 24, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Coffee Makers & Espresso Machines Logo
150 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
