Bascoo netbook no wifi - Computers & Internet
How to connect sylvania netbook to wifi
If windows is up and running make sure your wifi card is enabled (there's usually either a switch or one of the function keys will turn it on or off). From there in the bottom right corner look for your wifi icon or go to the control panel and find your wifi connection settings. From there just follow the directions on your screen to connect it to your wifi hotspot.
Dec 26, 2011 | Sylvania G-Netbook
7" Sylvania Netbook can't get WiFi towork. Powers
This is solved on the Sylvania g Netbook by upgrading to gOS 3.0, which uses ndiswrapper and the Windows driver. Good luck. @sigaieu
Aug 10, 2011 | Sylvania G-Netbook
What do i need to use my netbook wi fi, i also heard that you can use a wi fi phone with it
You will need a Wifi access point to connect your Sylvania Netbook using Win CE 6 to the internet. Some cellphones can act as "Wifi access points" but most cellphone network vendors will want you to pay $10USD a month to use that feature.
Free Wifi access points include McDonalds, your local public library, your church and other resturants. I have also found that all major interstate rest areas in IOWA have free wifi.
There are several lists of Free Wifi hotspots on the internet. I like this community effort listing: http://www.wififreespot.com/
The SN comes with a short wifi guide and there is a video as well as a step-by-step Wifi guide at www.digtialgadgets.com
Tom M.
May 11, 2011 | Sylvania G-Netbook
I BOUGHT THE 7"NETBOOK FOR
best way to connect to wifi is to use windows built in wifi connections. depending on the type of connection you will need to use a WEP key or WPA passphrase.
May 09, 2011 | Sylvania G-Netbook
I am trying to connect my netbook to the internet and it won't connect because it can't find an ip address i have looked and tried everything what do i need to do?
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
netbook router ethernet or wireless
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Mar 10, 2011 | Computers & Internet
My netbook will not go online I have tried my home wi fi and 2 diffrent public wifi
try to do the below troubleshooting :
1) Boot up your netbook. 2) Login to windows. wait until windows finish loading. 3) Make suer your WiFi is enable. Search for the button of keyboard shortcut like 'fn' + 'f2' (wifi symbol). 4) Search for wifi network nearby. 5) connect to one of them. 6) Usually, public enable wifi is using a DHCP setup. Go to you wifi adapter setup page and make sure it's already on DHCP mode. 7) You should be able to connect to the wifi network (public DHCP enable) by now. 8) If you still can't connect to the wifi, means its not a public DHCP enable network or you got a wifi adapter problem.
Good luck ;)
Mar 04, 2011 | Sylvania G-Netbook
My wifi on the netbook is not connected. How do you connect to web?
on the desktop, double click on the wifi power icon. click "on". then, bottom right, click on the wireless. find a wifi signal, and hit connect.
Feb 28, 2011 | Sylvania G-Netbook
Hi trying to connect my netbook to the internet
wifi connection? if you want wifi connection. just press FN ON THE SIDE IN YOUR KEYBOARD. AND PRESS F8 TO TURN ON YOUR WIFI CONNECTION.
Feb 01, 2011 | Sylvania G-Netbook
I received a sylvania netbook for christmas and it isn't giving me an option to connect to the wireless internet. is there something i'm missing?
First reset the router (unplug for 5 minutes, then plug back in) wait 5 min then turn on netbook---Be sure the WIFI switch is enabled on the netbook--check the taskbar for the wifi icon
Dec 27, 2010 | Sylvania G-Netbook
Computers & Internet Logo
David Payne
David Payne
