Question about Shimano M324 Clipless Spd Platform Pedals
I striped down the cleat mechanism on my SPD pedals, any ideas how to get the springs back in??
  • 37 Answers
There are parts on a bike that aren't ment to be taken apart because they are unservicable. Refer to Park tool .com Dood Luck
Posted on May 26, 2009
How do i install pedals
Right peddle has a right hand thread, normal, and left peddle has a left hand thread. On the left peddle you need to turn it clock wise to loosen it, counter clockwise to tighten
Aug 07, 2014 | Shimano SPD Mountain/Spinning Bike Cleat...
: Id like to change pedals of my mountain bike, which type should I prefer?
There are so many types of pedals. I recommend that you'll get a pair that you know and you are comfortable with. Or you can also check for reviews on pedals and take the ones with the highest rate. However, you should remember that what's fit some people will not necessarily fit you...
Check this link: http://www.vitalmtb.com/product/category/Flat-Pedals,20
Jan 14, 2013 | Cycling
Nail cleats are not exiting when the mallet hits on my Bostitch MFN-201. The spring mechanism appears quite loose; you can push it down or in very easily by hand.
That is most likely what needs to be replaced as that is the return spring. If it is weak it may not be allowing the driver to go back up far enough to let the next cleat load into the nose. Here is the parts diagram. Bostitch (Stanley Tool Works) just merged with DeWalt so you can get the part from either company now or a dealer of either company.
http://servicenet.dewalt.com/Products/Detail/MFN-201
Jul 23, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
The screws on my shimano cleats keep coming loose, causing major problems during rides. How do I fix this.
Go to your local auto parts store and buy a tube of locktite (for threads). Apply it on the threads of the screws and then tighten them down again (follow the instructions on the tube). There are set up time instructions on the tube - if you follow them correctly - you won't have any more trouble with them coming loose.
Jul 13, 2011 | Shimano SPD Mountain/Spinning Bike Cleat...
How do i fit cleats to shoes. holes don 't match up?
All SPD pedals use a 2-hole side-by-side mounting pattern. Your shoes must have this same pattern or this is no way to mount the cleats.
Look at the bottom of your shoes:
Is there a 3 hole pattern in the shape of a triangle? Then this is a Road shoe, it may or may not have the 2 hole option. If it has the 2-hole option then you will see generally one fixed hole and a long slot next too it. If there is no threaded insert then one has too be added. Some road shoes that are capable of having the 2-hole option need an internal adapter.
If you have mountain bike shoes (shoes that the cleat once installed is recessed), then you should see two side by side holes. Again some shoes need an internal adapter to provide the threading to screw into. These should have come with your shoes. If you don't see any holes, then you may have a cover that needs removing to gain access.
If neither of these is your scenario then you should consider visiting a bike shop to have them look at your shoes and see what the exact problem is. Any half-way decent mechanic or shop person could tell you in a couple seconds if the shoes and pedals are compatible.
Nov 26, 2010 | Shimano Pda520 Spd Clipless Pedals Bike...
One shoe won't snap into spd pedal
SPD hold on to cleats with a spring loaded action. This is normally adjusted with an allen key. Check that this is not screwed in so tight that action is locked up. If you don't have adjustment instructions go to shimano.com and download. You should be able to check for movement by pushing against spring clip with screwdriver (saves the fingers but mind it doesn't slip). If no movement also check for foreign body in pivot of clip. If all OK check for position of cleat in shoe. Make sure mount position is same as other shoe.
Dec 06, 2009 | Shimano M520 Spd Pedals
Fit pds cleats bike pedals
This site has the info:http://www.parktool.com/repair/readhowto.asp?id=156
Aug 30, 2009 | Shimano Dura-Ace SPD-SL Pedals
Shimano M324 Clipless Spd Platform Pedals Logo
154 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
