Question about Oreck XL Shield Power Scrubber Floor And Carpet Cleaner
How to use the oreck XL shield power scrubber
How to use it
SOURCE: Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
Posted on Mar 22, 2008
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
Hi do you carry the roller brush parts for this model?
Hi Rochelle,
This is Leland with Crucial Vacuum,
We carry the roller brush, and some other products for the Oreck XL, which you may find in the link below:
http://www.crucialvacuum.com/catalogsearch/result/?q=oreck+xl
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendlycustomercare representatives on the line ready to assist you.
Jan 29, 2016 | Oreck XL Power Team Upright Vacuum -...
My oreck xl has no power
Hello Donna
No power as in no electricity, or no power in that it has lost suction?
I have had a number of Oreck XLs in a hotel setting. They are a great machine.
Dec 11, 2015 | Oreck Vacuums
Trouble attaching nozzle to xl
Oreck is junk, despite the ads. trade it in on a Royal and yuu problems are over.
been in the vac repair business for 20 yrs
Jan 05, 2014 | Oreck XL Shield Power Scrubber Floor And...
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
I have an oreck xl shield scrubber and cannot remove the water tank. help
Make certain the yellow retaining latch is DOWN. Sometimes it LOOKS like it is all the way down when it isn't. Chances are, the tanks outlets were not properly greased, causing an o-ring to stick or roll off the seat.
Simply push down on the tank HARD at the top of the handle. You may have to strike it a few times but it will come off. It is best to do so in the upright position, rather than with the wheels extended. Once it is off, check the o-rings, re-seat if needed and apply some white grease to enhance the seal and prevent future sticking.
-Jeff
Oreck owner
Sep 06, 2010 | Oreck XL M900A Upright WetDry Vacuum
Oreck XL suddenly lost power
wiring in handle has loose connection or the brushes in the motor needs replacing. cost $18 for new ones.
Mar 08, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Shield Power Scrubber Floor And Carpet Cleaner Logo
46 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
