Question about Panasonic PT-51HX41 51" Rear Projection Television
My Panasonic Projection TV PT-51HX41 shuts off after a few seconds & won't turn back on.
  • 65 Answers
SOURCE: power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Posted on Dec 09, 2006
SOURCE: Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Posted on Oct 11, 2008
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
Hello I have a Panasonic PT47WX53G and when I turn it on the red led (Power) comes on and then blinks 5 times, then it turns Off. After a few seconds the red led turns on again blinking 5 times. This cycle repeats until I unplug the TV.
Thank You Willie
Posted on Jun 01, 2010
SOURCE: Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Posted on Jun 14, 2010
Greeting: I have a panasonic PT-51HX41E tv and when I turn the Imaje is hard like 3 seconds and off. Then unplug and re-provided plug and turn on and does the same,thanks for your help.....
Look to see if sets power light blinks a sequence after it shuts off. The most common on this model is a series of either three OR five blinks.
Let me know what you find and I will assist you.
SD TECH
May 17, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Converter box trouble
hello no the only thing the box does is it takes digital signal and convert it in analog signal and cannot do any hurt your tv at all u will be just find marty
Oct 14, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 TV shut off problem
the tv is in prot mode the mirco is seeing something that is wroung and it will not let the power supply come up. now i can be alot of things in the circuit but without checking the systems there is no way of telling what is the problem just rember big screens will cost u to repair one is 200.00 - 600 dollars.if u are lucky u could just have bad connections on the vert output transistor-or your convergance ic shorted out . i hope this will help some what marty
Aug 25, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Replacing STK392-110 IC Panasonic PT-51HX41 51 in. Rear Projection Television?
Just put something under the connector (like a screwdriver)and lift up....they are very sturdy and I have never had one break for me.
Oct 06, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
check the micro chip on the system control board.it could be bad.
Apr 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
15 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
