Question about Health & Beauty
Sbm2 healthometer what is the amp requirements
I need a battery for my Model 840 Healthometer scale. Date on back Dec 15 02.What size battery fits as I don't have the old one.My battery place doesn't have one.
the hole for the battery will give you the clue
if it has a single groove with a spring at one end it will be either AAA or AA battery ( depending on the groove width
2 grooves will again be AAA or AA battery
a square hole with the terminals together in a plastic cap will be a 9 volt battery
a round hole with a metal finger will be a button battery possible a 2063 size
the owners manual will have the right battery listed or it will be listed on line in the manufacturers specifications for that model
Jul 15, 2017 | Healthometer Health & Beauty
I want to change the time and date on healthometer scale
Google (healthometer)(model)(manual) without parens to get instructions.
Jan 25, 2017 | Healthometer Health & Beauty
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
When it was brand new(hdm562dq-18) it was lost among all of the boxes. I found it again but the manual is missing. I am visualy impaired and i can increase the size of the print online or in a written...
Here is the only manual available online for this device (not the exact model number, but it is supposed to be the same instructions):
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
This PDF document requires the FREE Adobe Reader application to open.
Jun 26, 2011 | Health & Beauty
Where can I find manuel for model 681 DQ 63
http://www.healthometer.com/Manuals.aspx
^ This should be what you're looking for. Click the second link that says "Wt. Tracking & Body Fat" and then click the "BFM.." link. You need adobe or a similar program to open the .pdf file. This shouldn't be an issue but if you can't open it, you can download adobe here: http://get.adobe.com/reader/
Mar 12, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
