Question about Hardware & Accessories
GE simple set digital timer, model 15430 - Hardware & Accessories
SOURCE: My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Posted on Oct 19, 2009
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Posted on Dec 21, 2009
SOURCE: GE digital timer model 15086 doe not work
This timer requires a neutral wire, it may or may not be present in the back of your box as a group of wire nutted whites. It is NOT the single white switch leg.
Posted on May 27, 2010
SOURCE: ge digital timer how do i set
http://www.jascoproducts.com
select support and enter the model number (15079) in the search field. the manual is downloadable. One thing the manual does not make clear is that the two plugs in this timer cannot be set independently of each other. Whatever two devices you plug in will go on and off at the same programmed setting.
Posted on Oct 04, 2010
SOURCE: Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 27, 2011
Set the hour on clock on GE electric stove
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
No digital display on my ge 15132 timer
Reset timer and reprogram.
If functionality is not restored, then timer has gone bad.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
GE15132 digital timer from Home Depot has 1 year limited warranty.
Digital timers do not have replacement parts, and are susceptible to power surge such as simple power outage.
Buy new timer at Home Depot, and return defect timer in new package for refund.
Oct 10, 2012 | Hardware & Accessories
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Jan 30, 2011 | General Electric GE 24-Hour Power Strip...
Manual needed
You can download your manual from the following site as a pdf file. It lists as an install guide but has the set up information. You may need to do a search using your model number.
http://www.jascoproducts.com/support/timer-quick-start-guide.asp
May 29, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Hardware & Accessories Logo
256 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
