Question about Teac Audio Players & Recorders
Teac AG-V7700 keeps bowing fuses
The other day I saw a spark behind one of my speakers and afterwards sound stopped and everything but the light on the volume knob was off on the front of my receiver. So I opened it up and saw that one of the fuses had been blown. I unplugged it and removed all speakers from the back of the receiver. The fuse said 6 amps and 125 VE. I'm not sure what the E stands for but I went to radio shack and bought a package of 6 amp 125 volt fuses. I've put 2 of them in and each time they both blew. Did I get the wrong type of fuse? or is there a bigger problem with my receiver?
  • 24 Answers
I hate to say it but it sounds like one of the audio chips that drives the speakers shorted out! The high powered outputs (more than 7 watts) need both speaker wires to be ungrounded. You will need to find someone to replace the defective chip or else get a new unit.
Posted on Nov 25, 2013
3 Suggested Answers
SOURCE: volume control blew out
i hade the same problem with the same unit and fixed it my self.
turns out the chip that is screwed to the heat sink was blown, and the resister that controles the fan burnt as well.all i did is ,get a datasheet of the unit and toke if apart went to the parts store and bought what was needed. the chip that is screwed to the heat sink has a part number on it whitch if you cant find the same can be switched with equivilant chip (find a datasheet of chip).
then my fan would not run ,i notesed that the risister was shot , the resister is color code witch means the resisters values. its a prety big job since the reciever has to be almost completely taken apart but very worth while .its ben workin like new for about 4 years since the repair with no problems or isues. hope this helps ad good luke.
Posted on Oct 28, 2010
  • 6771 Answers
SOURCE: Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Posted on Mar 11, 2012
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
Teac AG-V3050. Everything looks right but puts out no sound to speakers. Have trien many speakers. Is there a fuse, reset, etc? Thanks
I nce had the relay for the amplifier die on one of my receiver. Basically this will allow the amp to power on and supply voltage to the speakers. Same thing though, i could access all of the menus, adjust setting, and volume but no sound because the amp never clicked on.
Oct 19, 2012 | Teac AG-V3050 Receiver
Keeps blowing fuse.
Dissconnect ALL speakers from back of unit then try to turn on.
If it works you have a speaker short.
If not, you have a more serious problem.
DO NOT replace the fuse with anything else but what was specified, as it can cause a fire!
Jun 14, 2009 | Teac AG-V8600
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Teac AG-V8520
same problem exactly
Oct 13, 2008 | Teac AG-V8060 Receiver
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
