I have a Motorola Razor M which locked up, immediately following their update. I have so many things which haven't yet been backed up because I am not up on computers. My ex. use to take care of all the computer/smart phone syncing issues. I do have Verizon's backup assistant and again I run into settings issues. It may be fine but I have a lot of sensitive data I can not lose and will not be able to replace. I did use google drive, but my ex left in between the time my previous smart phone croaked and now! Unless I can figure out how to bypass the complete lock up, which translates into shut down, I am afraid I will find I lost something that is gravely important to me! I have attempted to press and hold both power button and volume down rocker switch at the same time. I have also tried to simultaneously hold power button and the center of the volume switch. I have tried charging it with it's original adapter straight to the wall. I have tried hooking it up to the usb on my computer without any change. I have tried to let the battery die completely and plug it in to the wall just long enough to catch a little charge and try to power up. The only thing it will do is I get a solid green light when it is charging, both from the wall or hooked up via usb to the computer! I also tried to remove the sd card and turn it on without any luck and last but not least, I have tried to do all of the procedures in every combination possible. Now, twice I have called Motorola for help and both times their techs told me to try a partition boot? I was exasperated because you have to be able to turn the darn thing on in order to do this procedure, unless I am mistaken. Suddenly, I felt like no one was really listening to me! Motorola also told me that yes, I will loose all the data on the phone memory and unfortunately, just prior to the update, I realized that most of the data had been saved to the phone memory but I do not understand how. The little bit I do know to never save your data to the phone memory! Please, this is very important to me to at the very least, be able to retrieve as much data as possible... I am truly in distress! Thanks for any assistance anyone can give me! -D-
    New Friend:
How do you cancel you phone service with majic jack
Posted on Nov 25, 2013
3 Suggested Answers
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
  • 253 Answers
SOURCE: Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Posted on Apr 20, 2009
I have a Motorola Razor M which locked up immediately following their update.
You can pray that the info is on a sim card but don't get your hopes up. You cant do anything it seems. This is why you backup your data - especially before an update.
Nov 25, 2013 | Microsoft Windows 7 Ultimate for PC
Sudsidy password for t mobile motorola razar
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Razor ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
You can get the Correct the subsidy password at Theunlockarena.com/motorola-razor/rs13wp9/ and Unlock it easily.Follow the instructions below and unlock it step by step...
Motorola Razor Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Razor mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Razor mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Razor with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Razor is locked to.
May 15, 2012 | Motorola SLVR Cell Phones
Unlock code for a motorola razor
To Unlock Motorola RAZR get the Unlock code from here Simpleunlocking.com/motorola/rs16wp8/ and Unlock it from network lock.
Apr 10, 2012 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
My motorolla razor v3 is locked when powered up
take out batt hold * & # place batt on and power up once logo comes up release * n # and it will take u to service screen then follow command or just turn off
May 31, 2010 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
Unlocking code + Motorola Razor V3 Phone
here
http://www.mobileunlocksolutions.com/motorola-v3/rs1wp9/
you can get your Motorola RAZR V3 mobile model unlocked at very low cost ,full secure & Safe..
Apr 06, 2010 | Motorola Mobility RAZR V3
Accidentally locked my razor keypad
If you have not previously set a security/lock code, when it asks you to input the unlock code, enter in the last 4 numbers of your cell number. If that does not work, you can use 0000, 9999, or 1234. Those are most common used default codes. If that doesn't work, see if your phone will allow a network update with *228 or *22899 followed by the send button. If a network update goes through, that will usually reset the code back to default if you had ever changed it, then try the last 4 of your cell number again.
Sep 13, 2008 | Motorola Mobility RAZR V3
Frozen razor
it may be a memory card problem.. sometimes if it is corrupt phone behaves like this.. remove card and then try switching on.. if this also does not work out then give your phone a new software update.. so that a new software is installed in your phone.. http://www.motorola.com/customersupport.jsp
follow this link and you can find some useful information on software update.
May 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razor v3 clock setting problem dilema
Disable the "Automatic update" feature and set the clock manually.
To do this go to Menu, settings, initial setup, time and date, Autoupdate>Off, then set the clock and date.
May 01, 2008 | Motorola Mobility RAZR V3
Garmin Nuvi 660 - Razor V3XX
Ok very easy. Your RAZOR is not properly recognize by the GPS. Your GPS unit is ok. It's just a little firmware update. Did you do ?
Try to delete your old connection and try again after the firmware update.
if don't call again GARMIN but ask for Automotive technician 2 shift.
Mentionned your problem with the RAZOR and ask if the last firmware include the update for MOTOROLA.
I had one MOTORALA not a RAZOR and it work fine. it should with MOTOROLA.
Best regards
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Bluetooth hs850
On the following link you will find a very useful pairing guide that will take you through the setup. http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=fd13e7af976c9010VgnVCM1000008206b00aRCRD Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Motorola Mobility Universal Wireless...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
