Question about Hillsdale Outback Queen Size Slat Bed, Nightstand, Dresser, & Mirror
Slat bed assembly instructions - Hillsdale Outback Queen Size Slat Bed, Nightstand, Dresser, & Mirror
We have another Home Sullivan bed that has a lot more slats. This one only came with three. How can I order more slats and leg sets for those slats?
If it is new then just return the bed or ask the place you bought it from to get you more slats.
If you bought it used order some.
If your are ambitious you can take a slat to Home Depot and they can cut and make you some more.
Sep 08, 2015 | Furniture
I have 4 metal rods that I am not sure where they are placed in between slats for bed frame. How are they assembled?
these rods will be to hold the frame parallel and not allow the sides to spread out and drop the slats out. check for nuts if threaded or if the ends are bent then look for holes in the top of the frames
Dec 26, 2014 | Cars & Trucks
What is a slat bed?
A slat bed is a type of bed with built-in frames that support the mattress without the use of a box spring. The slats run parallel to each other and are secured on each end to the frame of the bed.
Aug 19, 2012 | Furniture
I just bought a HOPEN bed from from Ikea. I am following the instruction manual; however I seem to be missing a piece. They are asking me to attach the SKORVA midbeam, but I don't see it here.
I also have the same bed frame from Ikea. The SKORVA midbeam is a separate piece (included in the price of the frame), but sold independently. Make sure to go get both this piece and a slatted bed base (if you haven't already).
Aug 16, 2012 | Furniture
I need instructions for a futon bunk bed I bought from big lots
Without knowing the exact model or manufacturer it's difficult to find assembly instructions, but the resources below may be helpful.
  1. Assembly Instructions for Round Tube Twin over Futon Bunk Bed (item no. SBP011-1): http://www.simplybunkbeds.com/images/pdf/SBP011.pdf
  2. General Bunk Bed Assembly Guide: http://www.bunkbeds.net/bunk-bed-assembly.html
Best of Luck!
Aug 15, 2012 | Coaster Black Metal/Dark Oak Twin Over...
We have the 4 in 1 convertible Munire Essex Crib Model 7100 from June 2009. We are trying to figure out how to lower the mattess as our daughter is tall enough to now stand in the crib and could fall out.
Take it back!!! We just converted our crib (which worked fine as a toddler bed) into the full sized adult bed. The frame only fits a mattress. We purchased a set and when completely assembled, it was DANGEROUSLY high. We removed the box spring and the mattress now fits fine. Now we are stuck with a box spring we paid for and cannot use.
The slats that get drilled in to support the underside of the mattress seemed slightly short, but we assembled it anyway. After one night of a 27lb. 3yr old sleeping on it, one of the slats broke. I laid on the bed to read her a story and CRACK! I am an average sized woman (around 145 lbs) so it's not like there was an obscene amount of weight on the bed. No one jumped on it either.
Now we have part of the mattress sagging through the middle- no doubt ruining the mattress as well. Just tried to send an email to the company- shocker- it came back as "user unknown".
Great.
Jun 14, 2010 | Toys
Bambino Reale 312C crib conversion to double bed
I have the directions- but it is poorly written by the company...
I could scan and email I guess - if you still need them.
Nov 06, 2009 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
Vicki 4 in 1 Convertible Crib...... IS NOT ABLE TO CHANGE INTO DAY BED OR TODDLER BED! I was shocked to learn this weekend when I went to convert my sons crib into a daybed that it can't be done. My crib...
Nevermind........... I think I found the soloution
they included the wrong instructions with my crib. They included the instructions for an old model
i need to get the toddler attachment because it supposedly has legs
will order it and hope it does what they say it will
** fingers crossed
Mar 23, 2009 | Sorelle Vicki
Simplicity for Children Aspen 3 in 1 Convertible 8750 Crib
I have this exact bed and just today I converted mine to a toddler bed.  I was scrambling for instructions until I realized they were permanently affixed to the mattress slats. (LOL)  I would be glad to help you out if you still need some help.  email me at c_l_m_21@yahoo.com and I can email you a scanned copy of the page you need.  There is only 1 page of instruction for baby into toddler.  I'll be looking for your email!
Cindy
Jun 22, 2008 | Baby Gear
Hillsdale Outback Queen Size Slat Bed, Nightstand, Dresser, & Mirror Logo
634 people viewed this question
Top Hillsdale Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Hillsdale Furniture Expert? Answer questions, earn points and help others
