Question about PC Chips (M925G) Motherboard
Blue screen problem
How blue screen error accurs and how to shortout
  • 27 Answers
When you get a blue screen that means you did not install the drives right call your computer manifacter and ask them how to install your drivers the right way. but that means you have to uninstall everything on your computer so make sure you backup all your files.
Posted on Oct 10, 2007
SOURCE:
What is error code E247-0004 in ir6570 Canon
u have to use the same counter and serial pcb . no way to bypass it as far i now.faced same problem
Apr 19, 2012 | Office Equipment & Supplies
Blue screen on laptop
If the laptop has any messages before the blue screen appears, please share them here so we can better understand and troubleshoot your problem more accurately. Make sure you do not have and CD/DVD or USB sticks mounted when you boot. These could interfere with normal hard drive boot operations. If you do have a bootable CD/DVD such as linux or antivirus utility disk, do they boot normally? You may have to reinstall your operating system.
Dec 31, 2011 | Computers & Internet
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Blue screen
First off next time you get that bsod error message write down the actual numbers on the blue screen those can be looked up for a more accurate meaning to the error.
If you can get a "copy" of Windows XP and use your Valid License number (probably on the bottom or back of the PC on a sticker) it will still work just fine and is legal.
Jan 04, 2009 | Dell Inspiron 9100 Notebook
Blue screen reboot issue that does not really reboot.
most of the time when this accures you have a virus and will have to
wipe and reload with restore dxisk
Dec 05, 2008 | Abit NV8 (890552603459) Motherboard
D:\ can't open in win 32 mode error
D:\ is not opening how can i shortout this problem plz suggest me
Sep 23, 2008 | Microsoft Windows XP Professional
Dvd play back blue screen
I recently got the same problem on this model. The component outputs still work but I don't get video or audio on the baseband outputs. I emailed Sony support and they said take it to a repair center. Am still looking for a solution.
Nov 01, 2007 | Sony DVP-NS300 DVD Player
PC Chips (M925G) Motherboard Logo
44 people viewed this question
Top PC Chips Computers & Internet Experts
Thomas F. Schneider
Ekse
Alun Cox
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
