Question about Sherwood RX-4103 Receiver
Receiver shuts off when music starts - Sherwood RX-4103 Receiver
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
Receiver keeps shutting off after 3 seconds. what
Be sure the face is secure, and there is no dirt in the connection on the face, and head unit.
Sha'ul
Jun 27, 2009 | Harman Kardon AVR 120 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
Alpine 9813
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
Jul 19, 2008 | Alpine CDA-9813 CD Player
I took my Denon receiver to a local repair facility, because it wouldn't fully "boot", after shutting down, when I tried to run a computer rca plug (on both ends) from our computer to a in wall -...
Please post the exact symptoms. What do you mean by not "booting up"? Does it click on then click off? This would mean that the unit is in protect mode which is usually caused by a problem with the output amplifier section not the Micro. Do you have any experience with electronics repairs? If so, I can try to guide you through the repair.
Let me know.
Dan
May 09, 2008 | Audio Players & Recorders
The receiver sound shuts off
There is a problem with the receiver that is allowing DC voltage to get to the output amp section. This is detected and the protection circuit shuts down the receiver. Yamaha uses coupling capacitors between sections to prevent this. If one of these is defective, it would explain your symptom. This should be a relatively simple repair for a repair shop. Expect $10-$25 for parts plus the local labor rate.
Dan
Mar 18, 2008 | Yamaha RX-V992
Denon 2106
Try making sure the plugs are snug. Always helps me!!
Dec 08, 2007 | Denon AVR-2106 Receiver
Sherwood RX-4103 Receiver Logo
23 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
