Question about Refrigerators
Hvt18dfbb needs peltier module - Refrigerators
Why doesn't it cool?
If I unplug the Peltier the unit starts right up, the display working again and fans come on . Is Peltier shot ?
I also can't find the 4.5inch fans for unit Fan Model # SD1225S12L. What would happen if I leave Peltier unplugged ??
Dec 17, 2015 | Cuisinart CWC-1600 Private Reserve Wine...
I have a CWC 1600 everything works fine on it but it does not get cold. Everything powers on fine and you can adjust the temp up and down but it just does not get cold.
Your Peltier is most likely shot! You can fix it for less than $10 in about 30 minutes.
Take the back of the fridge apart and remove the fan and aluminum heat-sync. Sandwiched in between the heatsync you'll see the Peltier pad with two wires coming off it. That's what you need to replace. The peltier has a make and model number on it. I would recommend ordering the same make and model. The specs should be 12v DC and less than 5amp and 60 watt draw. Your wine cooler's power supply can only output 5amp and 60watt max power. When you install the new Peltier you'll need to spread new thermal compound on both sides of the Peltier. I recommend Artic Silver Ceramique. You can buy this at your local Radio Shack or any computer store where they sell motherboards and CPUs.
Ceramique Thermal Compound
Apr 13, 2014 | Cuisinart CWC1600 Wine Cooler
Fan runs but it doesn,t cool
New TEC1 12706 Thermoelectric Cooler Peltier 12V Ceramique Thermal Compound
Feb 28, 2014 | Cuisinart CWC1600 Wine Cooler
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Coleman thermoelectric cooler not cooling
Sounds like the Peltier effect elements have failed.
http://www.tetech.com/Peltier-Thermoelectric-Cooler-Modules.html
Depending on your handyman skills, you can change them yourself or have someone troubleshoot and change them.
Sep 12, 2012 | Coleman 40 Quart Powerchill...
My Black & Decker bna17b mini fridge simply does not cool enough. The manual claims it should get down to 37 degrees Fahrenheit in a 70 degree room. I put the setting on high (coldest) and my milk...
Sorry Brian & Charles, but you missed the boat on this one.
This Black & Decker refrigerator uses Peltier Thermo-electric modules on heat sinks. If you blow off the dust and the unit still does not cool, these modules have probably gone bad.
The heat sinks/modules attach to the back of the fridge with two screws each. Unplug the power, remove the screws and then remove the heat sink/cooling fan units. On the refrigerator side will be a smooth plate with two wires coming out of it. Plug the fridge in and touch this plate. If it is not cold to the touch, your Peltier module is bad. You can buy new ones for about $20 each - Parts Express has the Velleman brand Peltier 2 model. But seriously, you'd probably be better off just buying a new fridge.
Nov 06, 2010 | Refrigerators
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
Refrigerator (s/n: AV051008384) refrigeration unit (Peltier) not functioning. The fan is functional. Removed PCBA, no visual evidence of electrolytic capacitor rupture or thermal overstress to components...
Hi and welcome to FixYa,
Peltier devices although not that efficient are known to be reliable. On your described problem, possibilities are:
  • thermoelectric (Peltier) module(s) (most likely) - the active cooling elements.  Most design have several sub-modules connected in series to form an array.  Failure of one in between will fail the entire module;
  • controller board  (likely) - or more specifically the section that regulates/control supplied power to the Peltier modules;
  • sensor (least likely) - most designs would have a sensor for the hotside forced ventilation system.   If the external ventialtion (fan) fails, then the controller board would prevent supply of voltage to the modules;
  • connectors (a possibility) - other than the Peltier effect, it is possible to have electrolysis on the terminals/connectors which would cause corrosion.  Check and clean all connectors to expose fresh metal, ensure tightness and positive contact.
An easy check is to test for the presence / absence of voltage to the module(s).  If voltage could be found, then it would be the Peltier module(s) that have failed. Absence of supply voltage would indicate the controller board to be possibly faulty.  To confirm, determine if there is power supplied to the controller board but none is in turn supplied to the Peltier modules. Absence of power going into the controller board would indicate a power supply problem.
Please exercise due caution when working with a live unit.
Good luck and thank you for asking FixYa.
Aug 31, 2009 | Avanti EC15W-2 Compact Refrigerator
Electric Cooler 40 problem
blow out the dust around the outside fan and heat sink
Jul 01, 2008 | Coleman Electric Cooler 40 Beverage Cooler
WINE COOLER
hello jelani372,
Happy you assist you.
You asked,
WHERE MIGHT THEY BE LOCATED I AM A ROOKIE I DO HAVE THE BACK COVER OFF ALL HELP IS APPRECIATED THANKS I HAVE THE HVT18DFBB MODEL
I believe this is the web site you asked for!
http://www.haieramerica.com/en/
Bless You,
Please rate me as solved, before you sign off please. Thank You!
Jun 22, 2008 | Haier HVT12ABS Compact Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
