Question about Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner
No heat but fan is working - Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner
    New Friend:
  • 32 Answers
If you're comfortable working around electricity then you might try trouble shooting a few things. Most HVAC (heat, ventilation, air conditioning) systems have a window which you can view the circuit board and a blinking led light. The number of blinks corresponds to the error code that is occurring. Some models have an explanation on the inside of the removable access panel. A few things to check for: Does the ignitor glow on start up? If not, the blower will start but then shut down. No glow, no ignition, the safety feature will not allow gas to flow. At that point, check the ignitor, it will be the cheapest to replace. If it glows, I would then check the sensor probe. If the sensor probe does not detect heat (or it went bad) then gas will be shut off for safety. After that, then I would move to checking the Controller Board. This is a little more involved and more expensive. But it really depends on how adept and handy you are. Good luck.
Posted on Nov 25, 2013
Fan not working on Whirlpool microwave Model MH2175xss1
What do you mean "fan doesn't work"? Magnetron will over heat without fan.
Apr 26, 2017 | Whirlpool Microwave Ovens
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Have a nutone 765hl-a heater blows but no heat
If the temperature control is turned up for heat but it is not heating, it is most likely a bad heating element or temperature control. Most heaters are not repairable.
Feb 19, 2015 | Dryers
Zafira radiator fan
Turning on the heat removes heat from the engine as it blows it on you. Make sure first that there are no air pockets in your cooling system as that can cause high temp reading and malfunctions in proper fan engagement. If that looks good test your fan, if it is working then test the fan relay, if it is working test the temperature sensor that gives the relay the go ahead to engage the fan.
Jan 16, 2014 | Cars & Trucks
My laptop is over heated now days and cooling fan also not working properly so what should i do ?
Hi, First blow out your fan and heat sink. Dust and lint may be causing your over heating issue. If you mean the fan is not working properly, due to it over heating this problem will also be resolved. If the fan is not working properly I.E. making noise, not spinning etc...Then the fan should be replaced.
Robert
Oct 20, 2013 | Computers & Internet
When heater is on the fan turns off. when we switch the fan on the heat element turns off but fan comes on. one or the other works but not both at the same time.
In some unit heat mode will start the fan after few seconds. Wait for max 3 minutes. If you turn it to fan mode, fan will only work no cool or heat will respond.
Dec 26, 2010 | Heating & Cooling
Soon as i turn on my heat my cooling fans come on first
It sounds like you do need a thermostat with your heat shut off and the gauge will raise a little then the car doesn't have that heat drawn from it indicating that you most likely do need a thermostat. As far as the fans coming on immediatly that could be a different problem it is most likely the coolant temperature sensor that tells the fan's when to come on. If this sensor says the coolant is hot the fans will come on immediatly. These are seperate problems as the coolant temperature sensor does not have anything to do with the cabin heating system. You should first check the level of your coolant is full, This could also cause your cabin heating system to perform poorly, and may have adverse effects to the engine cooling system. (fans)
Dec 31, 2009 | 1995 Nissan Maxima
Rheem 13PJL24A01 2 Ton 13 SEER Heat Pump Air Conditioner Logo
66 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
