Question about Yamaha Generator Portable 3000 Watt
Yamaha 300iseb battery drain
Drains battery al the time
3 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: We have 1992 Yamaha Venture.
If the battery is draining while the bike is running you have a failure in the charging system. Check your alternator and your voltage rectifier. While the bike is runnning, if you put a voltmeter on the battery at idle you should get around 13-14v. If you rev the engine up to 3-4000 rpm that voltage should rise a bit, say 1/2 to 1v. If you increase your electrical load (lights, heated grips or clothing, radio, etc.) it should rise a little more.
With the bike off and the key off, put your voltmeter's red lead on each fuse in your fusebox and the black lead to ground. Are you getting any voltage? There should be none on any fuse that does not have power while the bike is off. If you find voltage, note what circuit you find it on and check that circuit for a faulty component or shorted wiring.
Good luck to you.
Posted on Jan 10, 2009
SOURCE: MY YAMAHA SR 150 MODEL
All parts for SR150 is available at New Star Dagupan City.. I have 2 of this bike and got no problem for parts.. Since I bought them, i already changed the regulator, starter relay, spring for the kick, idle gear, clutch assembly.. One more thing, the engine parts are nearly the same as STX...
Posted on Jul 31, 2012
2008 Yamaha TTR230 Draining Battery
Replace your battery with new one because your existing one most likely became faulty with age.Even if you charge it it wont last. It is time for new one.
Feb 16, 2014 | 2008 Yamaha TTR230
Yamaha ybr125g
check the voltage as you remove or disconnect one circuit at a time, including all the lights and grounds on the bike, one at a time and see which one drops the voltage, find the circuit that is draining the battery
Dec 18, 2017 | Motorcycles
1990 yamaha xt600e starter turns slow .new battery new solinoid
First:It is draining amps,bad rotor bushing (will touch the walls),bad brushes (lack of power).Last:Bad valves timing gets to increased force to crank.Cheers.
Oct 23, 2012 | 1991 Yamaha XT 600 E
Can not find drain plug for antifreeze on 1990 Yamaha YZR 600
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Yamaha YZR 600 radiator drain plug Google Search
How to change coolant on Yamaha R6 for the first time YZF R6
http://www.thundercat.nl/index.php/download/category/2-manuals
OEM parts for Yamaha
YAMAHA YZF600R Owner Manual
Apr 27, 2012 | Yamaha FZR 600 Motorcycles
I,ve got 2005 yamaha 125 dtr it wont start spark was ltl damp when i tuk it owt battery just draining within no time what wud b the best sort of battery to put on
not battery the alternator not charging chech charge rate with amp meter on battery should rise when you rev bike.
Mar 20, 2012 | Yamaha Motorcycles
My 2001 yamaha r6 keeps draining all the water out of batteries ive replaced stator and voltage regulator
is battery more than two years old? if yes replace battery. Battery voltage should be >12.4 volts minimum. if it wont hold this charge its bad. Check all the wiring on your bike to make sure that you dont have a shorted system that is draining down you battery.
May 04, 2010 | 2000 Yamaha YZF-R6
2008 Yamaha wr 250f with a voltage drain on the battery.
Hi Explorer,
aside from hallogen fog lamps, i cannot think of other matters / parts of a bike that can drain the battery. this is a clear short issue. check the wirings and make sure that the circuits are harnessed, you'll see the difference once they are tied up. BTW, if the battery is a year old, have it recharged.
Jul 19, 2009 | 2003 Yamaha WR 250 F
My Fujifilm S9600 draining batts rapidly...
Hi !! With your comments I was thinking on al old problem that I have with a Fuji S7000 using a CF card, it drains the battery very fast, but the problem was the CF card, not the camera, I switch to a XD memory card and problem solved, Are you using a CF memory card?
Apr 13, 2009 | Fuji Rod Repair Kit
Battery not holding a charge,
Check the charging rate of your bike, see if its system is charging, if it does charge thn theres somewhere the battery is getting drained out.
In order to see if tht is happenning, switch off everything and thn remove one battery wire on the battery, after doing so try to fix it back and notice if theres any sparks when it comes to the contact of the battery terminal , if so thn theres a drain somewhere in the electricals and wiring.
Good luck.
Knight (Yamaha Seca XJ750A 1981)
Apr 12, 2009 | 2000 Honda VT 600 C Shadow
We have 1992 Yamaha Venture. Something keeps draining the battery. Can be driven home from work and by the time I get home the battery is drained. We also have a sidecar with extra lights. We have had this...
Good luck to you.
Jan 09, 2009 | 2008 Yamaha Royal Star Venture
Yamaha Generator Portable 3000 Watt Logo
Top Yamaha Computers & Internet Experts
Tony
Carlos L. Burgos
Carlos L. Burgos
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
