Question about Eliminator MotoMaster Mobile Power Inverter 700w
Hooked up to wrong polarity - Eliminator MotoMaster Mobile Power Inverter 700w
2003 pt cruiser hooked jumper cables wrong.have nothing with key on
U broke it and damaged it by screwing up the polarity of the cables. You are in deep doo doo. Could be the computer, anything.
Mar 03, 2017 | Cars & Trucks
Does cam have wrong polarity protection
All devices that are electronic and are not OEM have a diode in the unit that protects against polarity reversal. If it is ever hooked up wrong, the diode will short and the fuse will blow, the unit will not power back on until the diode is replaced.
Sep 25, 2016 | Radio Communications
Battery hooked up wrong
Disconnect the main battery to alternator wire and check again.
NOTE: DO NOT FORGET TO INSULATE THE REMOVED WIRE WITH INSULATING TAPE DURING THE TEST.
The diode rectifiers in the alternator may have become shorted due to the reverse polarity.
Dec 28, 2013 | Isuzu Cars & Trucks
No sound on anything on the onkyo 626
It will shut down if you have the speaker wires touching, or the wrong polarity of your connected speakers. Check the wiring and connect one speaker at a time. (turn off to connect)
Dec 27, 2013 | Onkyo Audio Players & Recorders
Hooking electric wheelchair battery to the fuse box and when the positive touches it sparks and smokes....whats wrong
tiny spark sometime normal but not getting hot! batteries are hooked up wrong. check polarity double double double check them
Oct 18, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Golf battery polarity
reversed polarity,check fuses. check the system for burnt wires also !
Always hook up your battery terminals correctly, as the alternator may be damaged if the battery is hooked up backward. jump start car, if it will. there should be at least 13.7 to 14.2 volts at battery posts while its running. if alternator is ok.
Nov 01, 2011 | Cars & Trucks
Subs positive negative polarity help
if its color coded,,red is positive and black negative,,,if not hook one up and watch the speaker while playin music,,, if its moving in and out its correct,,if not wrong
May 17, 2009 | AudioBahn AW1206Q Car Speaker
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
23 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Pierre Curtis
Level 1 Expert
L Pfaff
L Pfaff
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
