Question about Stihl 021 023 025 Ms210 Ms230 Ms250 Chainsaw Handle Bar
Fuel coming out of venthole on the tank
I have fuel coming out of the vent tube on the fuel tank,Have cleaned the tank.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Since you forgot to mention what saw you actually have, it's hard to answer but does it do it only after you have pushed the primmer bulb ???
Posted on Nov 28, 2013
Fill pipe cleaning
There is not much to go on here. Is it belching fuel back out of the fuel tank when your putting gas in. If so, there is a vent tube that goes down into the tank and if it is out of place, the tank can't get air while your fueling. Check your fill tube.
Apr 04, 2015 | Cars & Trucks
How to replace gas vent on huaqvarna 51 chainsaw
Disassembly
The fuel tank vent is located on the right side of the fuel
tank next to the right rear rubber element. With the fuel
tank empty and the fuel hose disconnected at the
carburetor, remove the two rear rubber elements. Separate the rear of the crankcase and the fuel tank enough to expose the fuel tank vent. Working through the fuel filler opening, grasp the fuel tank vent tube with a pair of needle nose pliers. Push the vent out the other side.
For access to the right side rubber elements, first remove the chain brake cover, bar, chain, chain catcher and cover plate.
For access to the left side rubber elements, remove the starter housing.
Assembly
Install the fuel tank vent using a drift the same diameter
as the vent tube. The remainder of assembly is the
reverse of disassembly.
Nov 07, 2014 | Garden
How to get the fuel tank vent to work?
OFTEN the whole fuel tank has to be sent out to a place to be boiled out clean with some powerfull acid to clear out the "vent tube." Try a wire hanger first, to clear it out.
Sep 20, 2014 | 1999 Chevrolet Silverado 1500
Why is gas pouring from the vent line when I go to start it
You don't say what kind of bike or give any other details so I will go with the obvious stuff first, I am guessing you might not ride it often or let it sit up for awhile. Gas pouring from the vent indicates that a float valve is stuck or the needle valve or seat seal has dried up and has fuel being forced around them as the fuel pump pressurizes the carbs. It is dangerous to run the engine with overflow as you could have a fire so your remedy will require you to pull the carbs to fix the problem.
Sep 11, 2014 | Motorcycles
Gas is coming out of the exhaust and vent tube.
The float in the carburator might be stuck and it is flooding.
May 25, 2014 | Mantis 2-Cycle Tiller
Bolens push mower Briggs mower when pulling fo start and running pushes gas out of the ventholes of the fuel cap.
I think that you have a defective gas tank lid that is not venting properly which could pressurize your system and cause problems. Invest in a replacement and hopefully this will solve your problem. The cap has a small breather vent cover [it sort of looks like a small mushroom], this allows air to enter the tank, but keeps air/fuel from going out of the cap. Some mowers use a pressurized system, and I am not sure if Bolens is one of them.
Sep 21, 2013 | Garden
P0446 ford escort 98
This Pinpoint Test is intended to diagnose the following:
  • Canister vent (CV) solenoid (9F945) (electrical concern only)
  • Fuel filler cap (9030)
  • Fuel tank pressure (FTP) sensor (9C052)
  • EVAP canister tube (fuel tank to EVAP canister)(9A228)
  • Fuel canister purge outlet tube (EVAP canister to EVAP canister purge valve) (9D661)
  • EVAP return tube (EVAP canister purge valve to intake manifold) (9G271)
  • EVAP canister purge valve (9C915)
  • Vacuum source line (input port vacuum to intake manifold)
  • Harness circuits: CV, FLI, FTP, EVAP Canister Purge Valve, SIG RTN, vehicle power (VPWR), reference voltage (VREF) and power ground (PWR GND)
  • Powertrain control module (PCM) (12A650)
This Pinpoint Test is used as an assistance in diagnosing the following EVAP components:
  • EVAP canister and bracket assembly (9E857)
    • EVAP canister sleeve assembly (fitting)(9D925)
    • Canister vent (CV) solenoid - hose assembly (9F976 or 9K318)
    • EVAP canister (9D653)
    • Canister vent (CV) solenoid (9F945)(mechanical concern only)
  • Fill limit valve assembly (9A086)
  • Fuel filler pipe flapper valve (9B085)
  • Fuel filler pipe check valve (9189), assembly (9285)
  • Fuel tank filler pipe (9034)
  • Fuel tank assembly (with fuel vapor vent valve) (9K007)
  • Fuel tank assembly (without fuel vapor vent valve) (9002)
  • Fuel vapor control valve (9B190)
  • Fuel vapor vent valve (9B593)
  • Liquid/vapor fuel discriminator (9G332)
  • On-board refueling vapor recovery (ORVR) T - connector assembly (9S314)
Description For additional information on the Evaporative Emission (EVAP) System, refer to Section 1A .
For additional information on the Evaporative Emission System Monitor, refer to Section 1A .
Pinpoint Test Schematics Escort/Tracer (2V)
May 28, 2011 | 1998 Ford Escort
Loosing power
The fuel filter is located just after the gas tank at the back. The filter is fitted to tube with standard tube fittings. You may also want to check the vent of your tank. You may just be having a plugged tank vent.
May 15, 2009 | 2006 Suzuki Grand Vitara
Gas shuts off every few seconds when filling gas tank
there is a vent tube that runs along side the fuel tank fill pipe, this tube allows air to went out as fuel is put in,if it kinks (it is very soft thin plastic tube) then u end up with your problem, replace the vent tube, the fill pipe and vent tube come as one part.
Jan 25, 2009 | 2003 Hyundai Accent
Stihl 021 023 025 Ms210 Ms230 Ms250 Chainsaw Handle Bar Logo
118 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
