Question about Emerson NR305TT CD Shelf System
How do i get stereo on and off volume does not click
On off volume control does not click won't turn on stereo
    Top Expert:
  • Emerson Master
  • 33,359 Answers
The switch part of the volume control has failed. The volume control will have to be replaced.
Posted on Nov 25, 2013
Volume control
your volume control encoder is dirty and either needs to be cleaned or replaced.
Nov 10, 2013 | Memorex Nostalgia 4-way Stereo Shelf...
Increase volume
Run a cable from "Audio Out" on your TV, to "Audio In" on your stereo.
Turn up the volume on your home theater unit.
Get hearing aids
Paint a "1" in front of the "63"
Can you not hear your TV? Is the volume supposed to go above 63? Do you have it connected to any externals like a stereo, or surround sound system? Between 0 and 63, can you turn the volume up and down freely, with no problems? We need a lot more information before we can help you out with your specific problem. Let us know and we'll get you squared away!
Jan 31, 2013 | Panasonic TC-14LA1 14 in. EDTV LCD...
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
Just purchased Samson dynamic microphone. Can we use this with a portable stereo or computer? If yes, how does it work? What do we do to set it up?
You can use it with a portable stereo that has a microphone input socket - just plug it in. You may need to adjust a mic volume control - this will vary from one system to another.
With a computer just plug it onto the microphone input socket (usually colour coded red or pink)
You will also need to enable it in 'control panel' - see below.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 14, 2011 | Samson Dynamic Vocal Microphone
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Broken Volume control
the stereo jackbus is stuck in headphone modus
unscrew remote and open up back part of stereo-connector repar switch and reassemble
Apr 27, 2009 | Creative Labs I-Trigue L3500 Computer...
Headset volume adjustment
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
Jan 21, 2009 | Logitech Premium Stereo Consumer Headset
Cant record in stereo
need more info.what are you trying to input what software do you use to repair.you could try opening volume control,properties.click recording put tick in box for stereomix.
to get to volume control ....click start.all programs ,accessories,entertainment.
Mar 03, 2008 | Dell Inspiron 1000 Notebook
32 in. iLo
If your TV is connected to a Comcast cable box that has a volume control on it with its on screen volume at the top of the picture. Turn it up until the word "stereo" appears and then only use the TV's volume control. This should fix the problem and allow you to enjoy stereo audio.
Jun 05, 2007 | iLO 3200 32 in. LCD Television
Emerson NR305TT CD Shelf System Logo
65 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
