Question about Caterpillar D6t Xw Elevated Sprocket Dozer With Ripper
Torque settings Please advise if we need to reduce the torque setting on 12.9 grade track bolts if we use Res Q Steel on treads. Some say you reduce torque up to 20 % to get the same touque as the delivered lubricated bolt this is normally just a fine spray oil .
  • Caterpillar Master
  • 3,961 Answers
I'd say not, if the standard bolt is oiled for installation. The MSDS on Res Q Steel
http://tradetools.co.nz/products/2835235
does not offer much info apart from the fact that it is an oxide loaded paste, seemingly like read lead. It does not have any moly compounds or other EP sulphur-phosphorus compounds etc listed in it, so it should not be any more slippery than the oil.
Basically that is what you would be concerned about, that this stuff will offer less frictional resistance as you turn the bolt, thereby giving a higher tension for the same torque.
12.9 is a high-stress alloy, in fact the highest in ASTM F568M. So on the face of it, unless you already have the bolt stress up near yield on oil coated bolts, there is no reason to reduce torque.
If it is a safety critical application, you should apply the Res Q gunk to a bolt, or 2, and torque it up until it yields and goes loose. Take a note of the torque reading on this test and you will know how much of a safety factor you have.
Posted on Nov 26, 2013
Stiga how can I stop my blades coming undone
You can go to the hardware store with the bolt before it breaks have them check the tread pitch and diameter of the bolt. They may have a pull card you screw the bolt into and it will tell you the diameter and tread count of the bolt. Once you know this get a grade 8 bolt in the same size. It is the strongest grade bolt you can buy in your size. Or get one in stainless steel they are strong too and don't rust.
Sep 20, 2016 | Garden
4610 ford diesel tractor water pump bolt torque settings
First you need to know the diameter of the bolts and the type of thread ie 3/8 N/C or 5/16 N/F then look at the type of bolt ie plain steel or high tensile SAE grade 3, 4, or 6, once you know this go to a general purpose bolt torque chart, and derive the torque spec info.
If the water pump is cast iron use the full torque specification.
If the water pump is alloy then reduce the torque spec 10%
Below is an example of a general purpose bolt / nut torque chart
May 05, 2016 | Ford Cars & Trucks
Torque settings for main and bigend bearings
If the engine block is cast iron use the full torque specification.
If the engine block is alloy then reduce the torque spec 10%
May 03, 2016 | 2011 Ford Fiesta 1.4
Torque settings for 2008 cpi supermoto 50
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your CPI despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
http://www.garage24.se/Catalogs/CPI/Servicemanual/Verkstadsmanual%20CPI%20SX%20SM.pdf
CPI Supermoto 50 2005
CPI SM 50
Nov 25, 2011 | Cpi yZF 600 R Motorcycles
Need to know what torque to apply to the head of the compressor 6HP-60Gal?
I don't find the VT618500AJ model listed in my manuals.
Measure the diameter of the bolt shaft, and find the Grade of bolt. Use the standard torque guide for that diameter, and grade of bolt,
http://zerofast.com/torque.htm
Do Not apply anti-seize.
Install dry. Torque pattern is start with a middle bolt, criss-cross over, and use a spiral out pattern. (Advise go in three stage increments when torquing)
Regards,
joecoolvette
Nov 06, 2011 | Campbell Hausfeld Air Tools & Compressors
How do I determine how much torque my impact wrench makes?
I test my impact wrench on a good vice and with a high grade steel nut/ washers and bolt that can take high torque. Select bolt with thread almost to the head. Hold head of bolt on solid vice and place two washers(more if needed to reach into threaded area) and nut on bolt. Set air pressure to max (I have 125psi). Run nut against bolt head with impact. Remove nut with torque wrench for reading. This low tech method will give you a rough idea. Higher pressure may give you better result. If you have used your air wrench for a while. Clean by adding diesel fuel into air fitting. Little at at time until diesel comes out rather clean. Then add a few drops of oil. Then test again. Good luck.
Aug 17, 2011 | Craftsman Tools 1/2" Air Impact Wrench...
Need torque spec on back 3 bolts of hub assembly on 2003 silverado 5.3 v8.
I belive that your talking about the bolts that sucure the hub to the knuckle . 50 TO 60 FT LBS is good its not a super critial spec unless for some other reason they are comeing loose witch wouldn't have anything to do with the torque spec anyway . Torque is determined by the diamater and tread pitch as well the grade of the bolt so a grade 8 bolt is much harder and stronger then a grade 2 bolt and the thread pitch is lower on harder bolts so they have more threads per inch . You can also tell by looking at the head of the bolt the more lines you see the harder the steel the bolt is made out of is So like i said its not super crictial and if there lock washers make sure you but them back ware they came from
Jul 14, 2011 | 2003 Chevrolet Silverado 1500
Need torque setting for header collector gaskets for small block chevy
There is no torque setting for those. Rule is to make them as tight as possible without snapping them. If you want to get real "fancy" use grade eight bolts as they are a bit harder to snap. Alternate between bolts as you tighten them down to prevent loading one side more that the other.
You can use a brass nut behind the steel one and use it as a "jamb nut" to help to prevent them from loosening up.
Nov 28, 2010 | 1996 Chevrolet K1500
Need torque settings on new upper ball joints
there's no torque setting that you go by because there aftermarket!
the factory ones are riveted in so you won't find it any where.
but when i do them and do them . witch is alot. i go by the feel of my air gun. if you are using just hand tools then i would use a 3/8 ratchet and tighten it as much as you can with that set-up , then get a 1/2 set-up and turn another 1/4 to 1/2 turn.
if you need a number for a torque spec then depending on the grade bolt that came with the replacement ball joint. a 10mm bolt thats a 8.8 grade will only do 33 ft. lbs. before it will strech and then break. so no more than that! 8.8 is the most common for automotive grade hardware...
good luck man
Sep 23, 2009 | 1996 GMC Jimmy
Caterpillar D6t Xw Elevated Sprocket Dozer With Ripper Logo
141 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
