Question about Dishwashers
Dishwasher sounds like a machine gun and shakes the house
Its an older Kitchen Aid dishwasher
    Problem Solver:
  • 16 Answers
Motor mounts or motor bad
Posted on Nov 25, 2013
Testimonial: "Thank you Bill for the reply! I will come back and let you know after I find out if it was either the motor mounts or the motor itself."
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
Oct 13, 2014 | KitchenAid Kitchen Aid - KUDS30FXBL...
I just got a kitchen aid regency portable dishwasher. My guess is its around 20yrs old. The problem is after i push the button to start it it flips off the breaker in the house. I tried different plug ins...
Really sounds like the water has leaked into some part of the machine and is shorting out the electric, or, some part has frozen up.
By all means, do not use this machine until it is fixed, or you may actually start a house or apartment fire.
Oh, yes. We have one of these dishwashers we use every 2 days.
It could also be the case you have a 15 amp breaker, and should have a 20 for this machine; or, you have accidentally plugged this in the where a house/apartment circuit is protected by a GFI breaker, and they will not take a portable dishwasher.
Be blessed.
Apr 17, 2013 | Dishwashers
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Not getting any water into the kitchen aid dishwasher
it could be the water inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 04, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Nov 25, 2008 | Dishwashers
Dish machine
you need a plumber sounds like your sink piping has a blockage
Mar 08, 2008 | Dishwashers
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
Owen Barnes
