Midea washing machine not spin/draining
I own a midea top loader washing machine MQB80-700B and i have lost the instruction manual. The machine won't spin to drain - the last time this happened was because there were coins blocking the drain - can someone tell me how to fix this please?
    Top Expert:
  • Washing Mach... Master
  • 36,514 Answers
The drain may have been clogged with something else.
Posted on Nov 25, 2013
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
aaronfitzy27
  • 12 Answers
SOURCE: Simpson 700L Top loader washing machine won't spin
If this machine is not belt driven, then more than likely is the motor coupler. To give you an idea of this problem follow this link....
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aaron
Posted on Jan 24, 2010
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
Posted on Jul 04, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
I bought a FS40-8MW/FS40-SMB fan and it was missing the small pieces. No plastic nut or spinner - Can you send these items to me at B.Townsend, 101 Vandenberg Cir, Roseville, CA 95747 Thank you
Alas Barbara Townsend,
I have a very soft spot in my heart for Roseville...
Specifically ... There is NOTHING ... FIXYA
only has FREE ADVICE.
>> Please...
EDIT this question and REMOVE your
private & personal information...
Name & address... (etc.)
((it is an IDENTITY risk you don't want... I assure you)).
Notwithstanding ... it appears you have an OSCILLATING FAN
MIDEA (currently listed under "DISHWASHER") is still a viable
manufacturer...
1-866-646-4332...
NONE of my usual parts suppliers recognize EITHER
MODEL NUMBER you posted... HOWEVER
eBay has proven quite helpful FINDING OBSCURE
bits & parts when I've been restoring things
(again... no exact matches (look for "donor" parts)).
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xmidea+fs40.TRS0&_nkw=midea+fs40&_sacat=0
Would that we could...
FIXYA is still only an independent ADVICE organization...
Hope this helps!!
Owners manual
Midea FS40 8M Instruction Manual
midea.com/us/contact-us
Midea Contact Us Best Home Appliance Brand Make Yourself At Home
eBay
19results for midea fs40
Carnac the Magnificent
Jun 20, 2017 | Dishwashers
MIDEA WASHING MACHINE INSTRUCTION MANUAL FOR MAE00-S2002GPS
Are you sure about the model number? I found an MAE100-S2002GPS washer on the Midea site. Go to http://www.midea.com/us/consumer/washing_machine/fully_auto/201404/t20140401_81499.shtml and click on the support tab for the manual. The direct link is http://img1.midea.com/us/Local_Library/info_instructions/washing_machine/fully_auto/201606/P020160614194954149229.pdf .
I hope this helps.
Sep 02, 2016 | Washing Machines
MIDEA AW70 509 WASHING MACHINE manual
Some manuals are here. If not similar to yours contact them direct.
Manuals Downloads
Dec 16, 2015 | Midea Heating & Cooling
Tear down instructions
follow outlet hose into mech its attached to pump
May 02, 2015 | Midea idea 1.6 cu.ft.Top Loading Wahing...
Midea instruction manual MAE70-S1402GPS
Haven't used the washer in a week. Tried using it today and this error code came up we unplugged it and replugged it like the Manuel said. The lids closed but it won't start. What could it be? It's only 7 months old.
Jul 19, 2014 | Midea 2.1 Cu. Ft. 6-Cycle Compact...
Leaking drum?
Is the filter cover fitted correctly?
Mar 07, 2014 | Midea Electric MAE70-S1402GPS 2.1...
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
I have midea AW60 9906 top loaded washing machine and i lost its manual
If you type into your search engine 'midea aw60 manual' you should be presented with a number of sources from where you can either download free or pay. At some point you will be asked for the other number.
Hope this helps.
John C
Feb 07, 2011 | Washing Machines
Washing Machines Logo
318 people viewed this question
Top Washing Machines Experts
