Question about Dyna-Glo (PPH16-LP) Utility Heater
My dyna glow propane tank will not ignite but has spark
5 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: were can i get a 16oz to 20lb propane tank conversion kit for a
try this http://www.portableheaterparts.com/ they carry parts for these units
Posted on Mar 23, 2009
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: i have a small dyna glo that takes a propane
There may be dust building up in the ODS safety pilot assembly. The simplest way toresolve this is to flish the pilot with rust buster. Why rustbuster? It has a telescoping tube that makes it easy to direct the squirt into the pilot. Let it dry then retry. You will be amazed.
Posted on Nov 10, 2009
  • 2557 Answers
SOURCE: dyna glo regulator won't
Does it turn anticlock wise ?
Posted on Dec 09, 2012
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Cannot get and flame.see spark from starter new tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
I have a Kenmore Elite He3 dryer that runs on propane. The dryer worked fine until i ran the propane tank empty. When I filled the tank the dryer worked but did not heat up. I bleed the propane line...
To check the igniter ya need to use multimeter set to ac voltage and check for 120 vac coming into the igniter if ya have 120 volts ac and the igniter does not glow the igniter is the problem. This tip i wrote covers what to check when a gas dryer does not heat
http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 24, 2011 | Dryers
My furnace wont come on its an automatic pilot so i dont know what the problem is we have enough propane
Hello, Most newer gas furnaces (propane or natural gas) has one of several different types of igniters. The most common one is called a hot surface igniter. This is a ceramic easy to break, glow coil, glowing igniter. Some has a Spark igniter that lights all the burners from a constant spark and some light the burners off a pilot proven /spark igniter. This one sparks then lights a pilot then the burners will come on. In any case if any of these types are not working they could be cracked or broke. Also the inducer draft motor has to be running, the little motor that hooks to the exhaust of the furnace ( if it has one ). This causes the pressure switch to close then the igniter should come on. My suggestion is to call a qualified service tech from your area to assist you. To determine which one of these may be your problem they will have to perform several test. Hope you get going soon. I hope this helped. J
Jan 27, 2011 | Coleman Propane Forced Air Heater...
I'm Looking to order some replacement parts for a dual head - Dyna glow, liquid propane Tank top heater
try looking them up online or go to there web site and that should have a customer service number you can call to get parts, also look on your heater for this information.
Jan 24, 2011 | Garden
Code 1F
"IF" or" Ignition failure", simply means you heater didn't fire. Be sure your gas is on,and if on propane be sure there is at least 30% in the tank (and the valve is open).Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Oct 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pilotlight will not light, getting spark, but no propane.
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Jan 11, 2009 | Century Tool 2320I Heater
Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Sep 22, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Dyna-Glo (PPH16-LP) Utility Heater Logo
24 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
