Question about Konica Minolta bizhub Office Equipment & Supplies
C 352 does not turn on
The machine is plugged in and it does not turn on
  • 794 Answers
Is your power source a direct plug-in to a wall outlet? Make sure both the upper and lower parts of the duplex receptacle are working properly; use a volt meter or in the absence of one, use a desk lamp or some other electrical appliance to test that the outlet is working.
If you are using a power strip or a combination power strip-surge protector, make sure the switch is turned "on" and that the internal breaker did not "trip"; press the reset button if there is one present.
The same way you checked the wall outlet for power, check the power strip the same way. Yes it is possible for any one of the outlets to be defective while the others work.
Check the power cords, make sure there is no loose connection or have been disconnected entirely.
Make sure the wall outlet is not controlled by a wall switch- on rare occasions I have responded to service calls where this has been the case.
Beyond that, you will need the service manual for that particular model printer to take you through the troubleshooting steps; which will require taking apart the printer's casement and exposing moving parts.
It could be a defective "on-off" switch; power supply; main board, etc. I don't know your skill level and if you are tech savvy.
You can contact the manufacturers' tech dept personnel; they may walk you through basic troubleshooting steps like I just did before authorizing a warranty repair or return repair order.
If it's no longer under warranty and its going to cost you more than half- or two thirds of what it cost you to buy the printer in the first place; go buy a new one and dismantle the old one for the precious metals and collect some money back on it. Copper, gold, stainless steel, and aluminum are at a premium these days.
Posted on Nov 25, 2013
Where do I find the engine identification number for a 352 that is in a 66 ford custom cab pickup?
always stamped into a flat machined part of the casting of the block of the engine, front, front left edge or front right edge. Has to be readily visible to an officer of the law.
Some locations and photographs are shown here.
http://www.bing.com/images/search?q=engine%20identification%20number&qs=n&form=QBIR&pq=engine%20identification%20number&sc=2-28&sp=-1&sk=
Go to Bing homepage
Jul 06, 2016 | Ford Cars & Trucks
My Toshiba e studio 352, when i copyed 200-300 pages then suddenly error occour e 010 then the machine does not copy a single page, cooling/stop machine 10 or 20 minute then i start copying again
sounds like it got a bit hot
tray holds 500 pages doesnt mean it can copy 500 in one session of copying time
Toshiba Studio 352 Copier Studio352
cant see it but
I was looking at the specs to see how many copies per hour it is rated
Jul 03, 2016 | Toshiba Office Equipment & Supplies
How to scan on TK-352
you can download the manual from this link directly:
http://www.kyoceradocumentsolutions.co.uk/dlc/gb/documentation/usermanual/fs-c1020mfp_aog_eng.-downloadcenteritem-Single-File.downloadcenteritem.tmp/FS-C1020MFP_AOG_ENG.pdf
Go to view the paragraph : Using the machine as a scanner
then you will know how to scan.
Jul 22, 2014 | Kyocera Tk-352
How to replaced developer in toshiba e studio-352 will i had try with 200 but still machine value is showing error
After replaced the developer material, u need to perform auto toner adjustment 05-200 ( take out the toner )
Dec 03, 2012 | Toshiba e-STUDIO 352 Black and White...
A friend asked me to thread her Janome 352 sewing machine without instruction book. The solution posted assumes that I know what all the parts are but although I have sewed for 30+ years I couldn't...
you can go to www.sewing.about.com and check out Debbie's sewing machines 101 guide. She has images, diagrams and general threading up.
or your friend can purchase a manual from here http://ifixmachines.com/vmchk/Janome-Model-352/Janome-352-Sewing-Machine-Manual/ilvm_fly1_blue.tpl.html
tally_girl_30.jpg looking at this image I would say "raise the pressure foot, take the thread from the spool holder at rear of the machine and take to the left and through the first thread guide (cant see one but there will be) then down the right side of the metal flat thing, through the guide at the bottom, then back up the other side of the metal thing and through the take up lever (turn fly wheel until this is tat its highest point to get access) then back downwards, through the thread eye near lower edge of machine head, then down to the needle bar thread guide and through the needle.
The tension device will be in that top area where the metal piece is and the horizontal white dial on left will be tension control dial.
I hope this helps you and your friend out, 4 thumbs up if so :-)
May 31, 2011 | Sewing Machines
Power Failure in viewer. Paper now jamming also. Toshiba e-studio 352
double press the fc button the machine cannot be switvhed off at the power switch it must be shut down press energy save button and shut down what paper jam error codes does the machine give
Feb 17, 2011 | Toshiba e-STUDIO 352 Black and White...
The turntable and the cassette work but the CD doesn't. Where in Florida can I get it fixed.
Here are several firms that claim to offer electrics repair in your area..
The Cartridge Family - www.cartridgefamilyinc.com - (352) 332-6495 - More
B. Mobile Revolution of Gainesville - www.mobile-revolution.net - (352) 332-2010 - 1 review
C. Appliance Direct - www.appliancedirect.com - (352) 373-0990 - More
D. Ashtin Communications - www.ashtincomm.com - (352) 377-8727 - More
E. Sound Ideas Home Stereo - www.soundideasstereo.com - (352) 378-0192 - 1 review
F. Electronics World - www.electronics-world.net - (352) 332-5608 - 2 reviews
G. Aabbea TV - aabbeatv.com - (352) 373-3614 - 1 review
H. Best Buy - www.bestbuy.com - (352) 379-8500 - 1 review
I. Home Theater Innovations By Bob's TV - www.htibob.com - (352) 245-2183 - More
J. The Laptop Repair - www.thelaptoprepair.com - (352) 374-2984
Please dont forget to rate well ;o) Thank you
Aug 07, 2009 | Philco (R) Classic Turntable CD Shelf...
Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Mar 31, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
AWM 352 washer motor connection
Look at laundry.manualsonline.com , search for awm351. A manual is posted that may help you.
Mar 30, 2008 | Washing Machines
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
