Question about GE Dryers
He plastic switch clips behind the back splash. are broken can they be fixed
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
You might try glue gun but more than likely it will need to be replaced
Posted on Nov 25, 2013
Mighty Bright clip-on Book Light. Broken switches - a plastic piece of the on-off switch fails and falls out.
Just buy a new one really if really need quick fix 1 dollar at store for 2 wire switch just tie wires one to first wire second to other wire to make bridge solder if u know how else just strip wires and twist together
May 02, 2016 | Home
Tip
Replace Turn Signal Bulb
If you look straight up inside the bumper you will see the plug that holds the bulb just twist and it will come out.
  1. Open the hood and remove the plastic clips that hold the front plastic splash guard in place. This is done by pushing on the center of the plastic buttons to depress them slightly. The button (clip) can then be removed. For the buttons (clips) with the philips head center, lift the philips head center until you hear a click and then remove the whole clip.
  2. Remove the plastic splash guard.
  3. Remove the three 10mm bolts that hold the lens assembly to the fender.
  4. On the fender side of the lamp assembly there is a plastic clip that is inserted in a small flange which is part of the fender. Use a flat screwdriver to put pressure on the back of the post that protrudes through this clip. This post, that is part of the lamp assembly, helps to hold the assemble in the correct position. Once that post is free of the clip the lens assembly can easily be removed.
  5. Un-clip the wires to the main headlights and the the parking/turn signal lamp and remove the lens assembly from the vehicle.
  6. In the case of a fast blinking turn signal, remove the turn signal bulb, test to be sure it is good, and clean the contacts of the blub, bulb holder, and the printed circuit strip on the lamp assembly.
  7. Reassemble everything and test.
  8. Replace the lamp assemble in the fender and secure the splash guard with the clips.
  9. This should be about a 1/2 hour job.
on Mar 17, 2010 | Lexus ES 300 Cars & Trucks
How doi fix the power windows in thefroont that keeps falling down?
The window is detached from the regulator. You have to remove the door panel and the plastic behind it . There are 2 plastic pieces attached to the window. There should be metal clips that hold them to the arms of the regulator. It could be that a clip came off and just simply needs to be put back on or the pieces have been broken off at which point either the regulator or window will need to be replaced. Both of which can usually be found at a vehicle salvage yard or dealership
May 07, 2014 | 2001 Pontiac Grand Am SE
Fluttering noise coming from left front inner splash shield area 55 to 65 mph.
check for torn/ mud flap behind the wheel. Check that the plastic splash panel under the front of the car is not broken and hanging down and flaps with speed from the air passing under the car.
Aug 25, 2013 | 2009 Lexus RX 350
The switch # 3949238 on my kenmore washer #110.29842991 is broken. how do I remove the top cabinet so I can replace the part?b
Disconnect the power first.
Many washers have spring clips holding the lid in place, and a putty knife or scraper can be shimmied in to compress the clips and open the lid for service.
Some units, esp old Maytags, have 2 screws near the bottom of the front panel, and removing them will let the front panel tilt out, granting access to the top cover from the front.
Some later Whirlpool and Kenmore units have a cabinet that comes off in one piece. You'll need to remove 2 screws holding the splash panel to the top of the washer. Flip the panel up giving access to the timer/switches area. Disconnect the white plastic wire connector, then use a screwdriver to pop the metal clips in the corner. Set these aside, and the whole cabinet will tilt forward, and can then be lifted off the washer base/back. Space to work will be an advantage, for this type of cabinet.
May 18, 2011 | Kenmore Washing Machines
The space bar seemed wobbly so i took it off to try and fix, and the clips and all came off. I am somewhat good at technology and figuring things out but i cannot get this space bar back on. How do i fix...
That depends on what kind of clips it used. Most laptops use these small plastic clips. Assuming it is not broken, you have to first connect the two plastic pieces together properly. This is noted by it laying completely flat and freely able to move around. Then place it back on the space bar as it will have slots it must slide into. Then place the bar back over the space it came out of with the plastic henge over the square space with a popup switch and press firmly until you here a click. It should lock into place.
If you continue to have trouble, take it to a professional. Something like this should be cheap and quick to get fixed.
May 14, 2011 | Computers & Internet
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
97 Lumina...Switch stuck on defrost vent and
I had same problem . There is a vacuum resovoir tank located behind the left front splash shield . The vacuum line behind the battery goes to it . I removed two 5/32 screws just in front of the tire that hold the splash shield to the fender , carefully flex the shield away from the fender and take a look . I found the vacuum line had come loose , plugged it back on and everything works . Hope this helps
Dec 20, 2009 | 1997 Chevrolet Lumina
Removing 2000 saturn fender
IF YOU LOOK ON THE INSIDE OF THE FENDER WELL, BEHIND THE PLASTIC SPLASH GUARDS, YOU SHOULD FIND THE BOLTS THAT ARE HANGING ON TO THE FENDER. HOPE THIS HELPS. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. PLEASE KEEP ME POSTED.
May 14, 2009 | 2000 Saturn SL
Lincoln mark viii
You will first need to remove the plastic piece behind the inner door handle that you use to pull the door shut with and there should be a 10mm bolt inside there behind the insulation. The plastic cover behind the inner door lever handle will need to come out. It's only in with clips. Remove the reflective lens on the end of the panel and you will see a phillips head screw inside. It's a long screw so be ready for many turns to get it out. Next, your power window controls will need to come out and they are only snapped into place but be careful with them because plastic prongs can be broken off if not pried out in the right direction. The same goes for the door lock switch. Unplug both once out. You will also see a triangle plastic piece (can break easily) towards the front top side of the panel. Make sure it clears it's way out when removing the panel. The rest of the panel is held up with downward facing plastic clips. Sounds hard but really it's all pretty simple. Study the back of the panel before putting it back on and take your time.
Jun 16, 2008 | 1996 Lincoln Mark VIII
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
