Transmission started changing gears in OD 85 vete 5.7
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Sounds like the selectors could be on the way out in the transmission. I suggest taking it to a transmission specialist.
Posted on Nov 26, 2013
I change motor&trans together when finished the trans. has no revers or netural
When you changed the motor and transmission, did you use the gearshift control assembly that came with the motor and transmission that you installed?
Or did you do an exact match-up of motor for motor / transmission for transmission and re-use the original gearshift control assembly?
Predicated that the transmission is used, like from a junk yard and had been sitting, it may be defective; or it's just a matter of readjusting the cables from the shifter control assembly to the crossover cables to the gear shift selector at the transmission.
That model production year included a 5-speed manual w/OD transmission; 3-speed automatic; and a 4 speed auto w/OD.
If you don't mind me asking what did you remove from the car?...and what did you replace it with?
Mar 13, 2015 | 1993 Dodge Shadow
My 85 c4 vetes transmission started shifting between 3rd and OD.
Nov 25, 2013 | Computers & Internet
What does the shift solenoid do does tell the transmission when to change gears as from 1 to 2 3 to 4 and 4 to od
Depends on the Year of the transmission. The more modern ones have a shift solenoid for each gear. On the newer trans the PCM activates and deactivates each solenoid to put the transmission in the right gear.
The OD on some is an electric lockup of the Torque converter. On the rest, the OD is another gear.
Apr 01, 2013 | Ford F-150 Cars & Trucks
Od light on
When you press in the Overdrive (OD) switch, this simply allows your gearbox to use the highest gear (when it needs to). For example, if your transmission has 1,2 & D gears, the OD acts as a 4th gear. This is useful on open roads and will help with economy.
If the OD light remains ON, then you have deactivated the 4th gear. This means the car will change up to 3rd gear only, until you depress the OD switch again.
Deactivating the OD is useful, when you wish to "manually" change down to 3rd gear, to climb a hill, or need better acceleration.
Mar 04, 2013 | 2002 Hyundai Accent
My 99 denali quit shifting into overdrive. Everything still seems pluged in. Any suggestions?
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
These will help.
Thanks.
Feb 15, 2013 | Cars & Trucks
Transmission not shiftin
GEAR SHIFT ISSUES
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Gear shift locks and car will not start
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Why Transmission fluid leaks near radiator?
Transmission fluid leaking?
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 19, 2012 | 1999 Toyota Camry
Where are my transmission sencors my car dosent shift right can u post a picture
there inside the tranny you have to remove the pan to see them but thats not going to be your problem go buy a can of TRANSX first!! and try that if that helps then you need to plan on rebuilding your tranny or replacing it
Jan 14, 2010 | 2003 Ford Focus
Transmission doesn't stay in one gear
possible faults - *check the shifting cable selector is aligned with the neutral starting switch * check engine mounts *make sure the fluid level is between the marks on the dipstick running hot * overdrive friction and drive plates have worn out * the torque converter or oil pump has a problem *do a torque converter stall test hope you used only mitsubishi automatic oil when changed *check the throttle position sensor * temp sensor for the auto the TCU has faults or needs to be replaced
May 14, 2008 | 1989 Mitsubishi Sigma
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
